Joined: Sun Nov 07, 2010 6:18 am Posts: 13 Location: Brisbane
Posted: Thu Jul 03, 2014 9:21 pm
Am looking for a place that sells an engine rebuild kit for a 94 Suzuki Swift DOHC mk3 1.3 ltr twin cam engine that is in my Sierra.
Hoping for a full rebuild kit for the weekend - am in Brisbane.
+ head gasket + intake manifold gasket + exhaust manifold gasket + valve cover gasket + valve stem seals + camshaft front + O-rings + front seal gasket + rear seal gasket + water pump gasket + time cover gasket + other small gaskets
+ timing belt + timing belt tensioner
+ oil pump + water pump
+ main bearing set + complete rod bearing set + thrust wasters
Users browsing this forum: Google [Bot] and 30 guests
