| G16a fuel pump pin missing https://auszookers.com/forum/viewtopic.php?f=8&t=50058 |
| Author: | Ahojok [ Sat May 09, 2015 3:03 pm ] |
| Post subject: | G16a fuel pump pin missing |
Hi guys just done a rebuild on my g16a vitara however somewhere in between taking off the head and sending it away for rebuild etc I have managed to loose the pin that comes out of the head into the fuel pump which I didn't even know existed till it was too late. I'm not sure what to do now. Does anyone know where to find one or any ideas on how to get around this problem I have put it all back together but can't start it due to a bloody tiny pin. Car is a 1990 g16a vitara 8valve carby. Any help would be appreciated thanks. |
| Author: | Scrawny [ Sat May 09, 2015 5:06 pm ] |
| Post subject: | Re: G16a fuel pump pin missing |
I've moved this to the 'I want it' section for you. Hopefully someone will have one floating around somewhere |
| Author: | Ahojok [ Sun May 10, 2015 1:09 am ] |
Thanks |
| Author: | Rhinoman [ Tue May 12, 2015 3:32 am ] |
Its the same as an SJ pin, during my engine swap I mislaid mine, ordered a new one and then found it was the same as the one I had in the old SJ head. |
| Author: | Ahojok [ Sun May 24, 2015 1:04 pm ] |
Hey guys I couldn't find the pin and Suzuki wouldn't even order one for me saying it's only worth $9 and Japan won't send just one out. So I got creative and fabricated one and it worked I now have fuel pimping into the carb. However after driving it two times my fuel pump has started spitting out oil very heavily like 4 liters in 20 minutes. I know the fuel pump needs replacing but do you think this will happen again cause of the pushrod we made or was it just a coincidence. Thanks in advance |
| Author: | Scrawny [ Sun May 24, 2015 2:13 pm ] |
How did you work out a length for the pushrod? It's possible it's too long but more likely it's just a shot pump |
| Author: | Ahojok [ Mon May 25, 2015 8:52 am ] |
We just had to keep adjusting it until it fit and we got fuel. Thanks |
| Author: | Jorynator [ Tue May 26, 2015 6:20 pm ] |
i think i have a few fuel pins in my spare pile if u still need one? pm me if u do. |
