I'm after the mechanical air flow meter from a pre '94 vitara G16. This is the one with the 5 wore connector with the moving internal cone as per the pic below.
Sorry for the slow response Chester. I'm not getting email notifications for some reason. The AFM connects directly to the air filter. If you look at the air filter box in the bottom right of the photo below it is the part that connects to the back left of the air filter box. This is in turn connected to the black flex pipe which runs to the aluminium pipe that runs over your engine to the throttle body. To identify it is the right one without removing it just check that the plug going to it has 5 wires.
Users browsing this forum: No registered users and 20 guests
