'94 - later model with screw type air filter box and 3 wire AFM.
This housing will either go into the above LWB or my '92 SWB. Reason for swapping is I am swapping air lockers from the SWB which are of 4.8 ratio from a GV into the LWB and so I need new ratios and could do a complete rebuild at the same time.
Am I correct in assuming the only changes are the 10/12 bolt centres?
Users browsing this forum: No registered users and 52 guests
