It is currently Sun Jul 12, 2026 7:29 am
Vehicle: green with red door
Post Posted: Mon Nov 02, 2015 8:28 pm
I've been looking on low range off road for a high steer kit but I want to move both arms up above my leaf springs as I have a spring over axel but all the kits just lifts the arm that goes from the steering box to the steering arm above the leaf spring, so if their is another kits out their that lift both above the leaf springs, cheers in advance
Post Posted: Tue Nov 03, 2015 8:56 am
look again, there are two stage kits that lift both arms
Post Posted: Tue Nov 03, 2015 11:29 am
Either kit will eliminate bumpsteer but the kit with two steering arms also raises the tierod to a higher position out of the way from damaging obstacles.
Removing my Captain Obvious uniform, the folks at Rocky Road Outfitters have a Stage I kit (one arm) and a Stage II kit (the Stage I kit with a second arm).
This is what I have on my WT Sierra equivalant (SJ-413 Samurai).
I am not sure if they make a Right-hand Drive kit... but you CAN adapt a Mercedes Benz steering arm to do the job with a bit of fabbing!
Do a search for mercedes at Ack's FAQ (see link in signature below) for several articles on the conversion.
I hope that this helps!
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Thu Nov 05, 2015 4:38 pm
Cheers guys
Users browsing this forum: Google [Bot] and 34 guests
