It is currently Sat Jul 11, 2026 4:10 am
Vehicle: 93 Sierra Tin Top
Post Posted: Thu Dec 07, 2017 7:59 am
Wanting to buy 2 sets of either 4.11 or 4.55 diff gears for a project sierra.
Gears will be going into 93 WT diffs, so all that is needed is the gears.
Might be a long shot but located Victoria.
Cheers!
Post Posted: Thu Dec 07, 2017 9:17 am
It’s going to be a VERY long shot because lj80/sj410 gears don’t fit in WT Sierra diffs.
You’ll need WT Maruti ratios, (4.1) or early Jimny rear (4.1)
There’s no 4.55 for the 1.3 WT diffs, you’ll have to use either 4.57 aftermarket gears or 4.6 vitara carby auto front gears
Post Posted: Thu Dec 07, 2017 1:02 pm
As always, I appreciate the knowledge, was under the impression that crown wheel PCD and pinion ID was the same.
Honestly looking for anything between 4 and 4.5 that can be used with WT diffs...
Post Posted: Thu Dec 07, 2017 3:42 pm
4.3 from grand vitara front diffs also
Vehicle: sc100 se416 mightyboy
Post Posted: Sun Dec 10, 2017 8:57 pm
Tanshi has it, 4.3 from a GV front, easily sourced for spares. I have got a pair if you want, happy to freight.
Why make your Suzuki like a Vitara, Just get one.
Vehicle: Suzuki Sierra Trayback
Post Posted: Mon Feb 19, 2018 7:43 pm
Have two complete Wt Maruti 4.1 diffs in NSW. Text 0457911623 if interested or more info needed.
Users browsing this forum: Google [Bot] and 7 guests
