It is currently Sat Jul 11, 2026 12:56 am
Vehicle: 95 vitara lwb h25a conversion
Post Posted: Fri Aug 10, 2018 7:16 pm
Chasing a H20a manual gearbox 5 Spd that’s running 20 tooth count on the input shaft and 23 on the gear .
Dimension on the input shaft still in box is 170mm from the internal side of the bell housing, The spigot pilot diameter is 15mm.
Otherwise if you’ve got a input shaft or know anywhere that does. The measurements are;
230mm (9 inches) in length 20 tooth spline the spigot pilot is 15mm (.55 inch).
Users browsing this forum: No registered users and 6 guests
