It is currently Mon Jul 27, 2026 1:47 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Sun Jan 10, 2010 6:34 pm
hey guy's i picked up a carby for a short period of time, i was going to run it till i got my stocko one fixed but now my stocko one is fixed im just going to play with it.
I know you can get like 36/38 what type is this?
what size jets do i need to run on a standard G13A?
cheers :D
Vehicle: MY2019 Jimny
Post Posted: Sun Jan 10, 2010 6:44 pm
I don't know dude, but I think your wallet is eating some paper...
Post Posted: Sun Jan 10, 2010 6:53 pm
that looks like the smaller 32/ what every they are. i have a 36/38 in the shed. they are pretty much the same carby just bigger
:lol:
i only wish the paper would turn into money...
Vehicle: jimny
Post Posted: Sun Jan 10, 2010 7:09 pm
pmsl..
anyway josh it should be stamped on the bas somewhere on the side.
you could just measure the throats though and be sure of it.
try googling jetting specs for 32/36 webber, thats what i reckon it is.
if you come accros any for A14 or similiar that would be close, oh and im no mechanic so if im wrong im happy to be corrected.
Post Posted: Sun Jan 10, 2010 7:35 pm
I think 38 DGxx, ES or AS depending on what choke it used to have
another thing, does it look like there has been a choke fitted at some time? if its never had one it may of been part of a multi carb set
either way its more a performance type, if I could find a manifold to fit it to my mini I would make an offer on it :)
Post Posted: Sun Jan 10, 2010 8:07 pm
haha it's not mine, and it's been to the states to get something done to it to make it idle on it's nose, so im keen as to see this bad boy up and running :D
this is what came in the box also, but im not sure if it's a choke....
also my vernier calipers say 38mm across... so what size jet?????
Post Posted: Sun Jan 10, 2010 8:25 pm
yeah its an AS then and thats a water choke like a sierra has
and the 38 in the model means 38mm barrels, oyull need to read up to see if they have swappable chokes and so on, there is sooooooo much more to tuning webers than getting the right jets in there
Post Posted: Sun Jan 10, 2010 9:03 pm
come on drop kicks, it has no jets, thats what i need to buy and i don't know what size they normally run...
Vehicle: jimny
Post Posted: Sun Jan 10, 2010 11:06 pm
does it have the emulsion tubes in it?
this might help a little
http://www.racetep.com/webercarbjet.html
Post Posted: Sun Jan 10, 2010 11:34 pm
if it has no jets look at what size a std 2ltr escort has and come 2 sizes smaller. that will get you going pretty close to what you need.
pic of what has been don to the bowl and float to make it work on nuts angles please!
Post Posted: Sun Jan 10, 2010 11:52 pm
haha no way, im not pulling it apart and it cost him (the owner) $500 to get this secret mod done :wink:
cheers luke and brett, it looks like what i was told previously is right.
45 main
45 idle
Ill go and buy them tomorrow 8)
Post Posted: Sun Jan 10, 2010 11:56 pm
I wonder how much blocking up the float vents and putting that breather in has to do with it, similar mod gets done to holleys to stop em spewing down the throats
Post Posted: Mon Jan 11, 2010 12:06 am
just buy a bowl gasket while you are there and take it off and get a quick pick :D i'll even pay for the gasket
Post Posted: Mon Jan 11, 2010 12:20 am
The owner was told to set his float levels, and tune it then it's good to go....
haha brett your way desperate... :lol:
Vehicle: SV420
Post Posted: Mon Jan 11, 2010 2:26 am
Hi 31 zook,
I have had two escorts so I can shed a little light - might not be on much but may help though.
The Australian 2.0L escort had a 32/36 weber on it. From 0 - 1/2 throttle only the primary would open up (I think the smaller throat - the 32 mm barrel) and from 1/2 - full throttle both would operate open up with both being open fully open at full throttle. You could look down the carb and tell visually the different sizes of the barrels.
In the second escort I had (RS) the previous owner had done a mod and made both throats open together with a linkage/cogs at the back of the carb like in your very first pic and you could tell both barrels are the same size.
Are yours 38mm across both? If so I think you have a 38/38
^^ a link from http://www.toyheadauto.com/PerformanceP ... nents.html
Sorry can't help on jets.
Post Posted: Mon Jan 11, 2010 3:26 am
yes both barrels are the same size. cheers ill have a good read of your link :D
Post Posted: Mon Jan 11, 2010 3:46 pm
38/38 webber tuning guide
I bolted it all down and now it revs to about 5000rpm then goes down to 500rpm then repeats the cycle. while it's doing this there is a high pitch whistle going when it revs hard.... im not touching the throttle cable while this is happening btw. do yas now how to fix it?
cheers :D
Post Posted: Mon Jan 11, 2010 4:03 pm
wierd but maybe airleak, spray some wd40 round the base ans stuff
Post Posted: Mon Jan 11, 2010 5:13 pm
yeah i was guessing airleak, there is a vacuum line comign off of it but im not sure if it's positive or negative pressure to make it run right....
Post Posted: Mon Jan 11, 2010 6:11 pm
hey i didn't tighten the base down enough, so it was leaking there.
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
twin 38's, still in need of a good tune, but hauls ass already 8)
Post Posted: Mon Jan 11, 2010 6:19 pm
but if you put your foot down it floods... :(
Post Posted: Mon Jan 11, 2010 6:53 pm
how do you know it floods?
Post Posted: Mon Jan 11, 2010 7:50 pm
you put your foot down and it dies but if you back off and let it breath again it comes back to life. is that flooding?
Post Posted: Mon Jan 11, 2010 8:00 pm
no I reckon youll find thats leaning out, not enough accelerator pump jet, its its changeable
generally missfire is lean, rich will jsut feel gutless and blow smoke
Post Posted: Mon Jan 11, 2010 8:17 pm
yeah you got it in one, the way it's running is still going harder than the stocko.
so how do i fix it? bigger jets? Im running 45s but ill try 50s later,
and it idles at 2000rpm most of the time with the idle screw not touching the throttle assembly, what would cause this?
will it damage my motor running like this?
sorry for all the questions...
Post Posted: Mon Jan 11, 2010 8:24 pm
youve still got big air leaks somewhere
Vehicle: 92 Suzuki Sierra
Post Posted: Mon Jan 11, 2010 10:06 pm
once you done or a tank
or two let us know your crazy fuel economy.....
-Santos
Post Posted: Mon Jan 11, 2010 11:07 pm
MMMMM 38 syncro 8)
Yes josh there must be an air leak somewhere I had it down to 900rpm.
How did you go with the "light" reading I gave you lol.
Remember the 38 uses both barrels at the same time so mix has to be done the same both sides.
You will LOVE the power.
Nik
No zooks just VWs
Post Posted: Mon Jan 11, 2010 11:09 pm
P.s. I forgot to say be careful tightening it down as it can warp.
You wont need the choke when its set up right Ive never ran a choke on my webers.
Check for leakes to get rid of that high idle.
Nik
No zooks just VWs
Users browsing this forum: Google [Bot] and 371 guests
