It is currently Tue Oct 27, 2026 1:31 am
Post Posted: Sun May 02, 2010 7:17 am
I have found a swift 16 valve head and complete tbi setup has anyone used this combo?
Are there any problems using the 16v head on a 1.6 will the tbi run the 1.6 or will it run to lean?
Are there any inherant problems with the swift tbi?
Post Posted: Sun May 02, 2010 7:42 am
i bought a old swift when i was at perth for a run around car and then to strip it for the engine it had the same set up on it. it was all standard besides a dirty 2" exhaust on it. i had no problems with it. it was a gem didnt miss a beat. and i had to take 5 blokes to work each day. i didnt find any problems with it.
Post Posted: Sun May 02, 2010 7:53 am
Thanks for the reply mate I mainly need to know wether there will
be any problems fitting this setup to a 1.6 in a Sierra
Post Posted: Sun May 02, 2010 9:25 am
yer thats wot im doing at t moment. got the same set up. the only problem is the dizzy need a right angle drive.
Post Posted: Sun May 02, 2010 10:09 am
Yeah that was my main concern could you use a vit 16 valve dizzy instead? Or are the heads completely different? I haven't bought it yet I wanted to be sure I wasn't wasting my money
Post Posted: Sun May 02, 2010 10:35 am
gti head?
u will need to block off the injector ports, make a custom manifold etc
or are u talking the 1.6? tbi ones?
Post Posted: Sun May 02, 2010 11:02 am
It's a 1.3 16 valve tbi swift not sure but I think 1.3 not a gti they are mpfi of course
Post Posted: Sun May 02, 2010 11:15 am
as far as i know the swifts never had a 1.3 16 valve tbi, only the swift sedans had a 1.6 16 valve tbi.
the tbi is a good system, but the head istelf is rubbish. all the ones i have dealt with have cracked, to the point where i was making adaptors for the tbi manifold to vit 16 valve mpi heads.
the tbi heads and vit 16 valve heads may appear the same, but are two completely different castings.
Post Posted: Sun May 02, 2010 11:31 am
Thanks Joe that's what I was after. I'll just grab the tbi setup then it's prbably the reason it's at the wreckers, it was a sedan too I'll retro fit it to my 8 valve head I am really only after the efi just thought the 16 valve head would make it go better.
Post Posted: Sun May 02, 2010 11:37 am
it Will make it go better. if you can get the head cheap enough it is worthwhile sending it off for a crack test. they are pretty easy to fix nowadays and that tbi would suit the 16 valves better as the 8 valve tbi is half its size.
Post Posted: Sun May 02, 2010 12:52 pm
Ok I'll see how I go depends on the price I cab get it all for if I could track down a vit head I'll go that way to get around the dizzy problem making an adapter won't be a problem
thanks for the help mate
Users browsing this forum: No registered users and 343 guests
