It is currently Tue Oct 27, 2026 12:37 pm
Post Posted: Sun May 23, 2010 12:33 pm
the clutch slips pretty bad now =[
i know it's been coming
so it's time to put a new one in =]
will be doing it myself so any hints or tips (haven't done a clutch before)
and anyone suggest a brand? HD or standard?
thanx heaps
Ben
Post Posted: Sun May 23, 2010 12:41 pm
http://www.bigjimny.com/images/document ... Clutch.pdf
these articles are pretty good. jimny specific as well.
mine will also need replacing sometime, not too sure when but its on its way out.
post up how it goes and take plenty of pics, ill have a go at doing it myself also.
Post Posted: Sun May 23, 2010 12:48 pm
dont think that link worked
if not, try this and click changing the clutch
http://www.bigjimny.com/index.php?optio ... &Itemid=61
Post Posted: Sun May 23, 2010 1:24 pm
sweet that should help alot =]
Post Posted: Sun May 23, 2010 11:20 pm
I got a Exedy HD installed when I got the motor recoed.
A lot of people say stay clear of the HD clutch because their renowned for
snapping cables because there to stiff, but I can't feel any difference through the pedal at all.The clutch has some real bite to which I like.
The funny part was my Mrs opened the box and she said "look it's pink"
And I said "yeah all boxes are pink inside" :lol:
I had a welt from where she smacked me for about a week.
Post Posted: Tue May 25, 2010 12:09 pm
ordered a extreme hd clutch today http://www.xtremeclutch.com.au/
should come in a week or so...
so get to learn to do a clutch next.
any tips?
Post Posted: Tue May 25, 2010 12:26 pm
any tips?
Thay are a piss easy box to get out, just take your time.
If it's never been out before, all the bolt's are going to be F*#KING tight.
I busted a Snap-on ratchet on a bell housing bolt.
Post Posted: Tue May 25, 2010 12:45 pm
will get the breaker bar on those then.
how will i go getting the flywheel off to be re faced?
Post Posted: Tue May 25, 2010 1:40 pm
I have an Exedy HD sports tuff clutch as well. It will be really sensitive when you first drive with it.
No doubt you will stall the Jimny a couple of times :)
Bloody good clutch so far.
09 Jimny Sierra Limited Edition
Post Posted: Tue May 25, 2010 10:45 pm
they just bolt up dude, undo the bolts and wiggle it til it comes off.
also make sure you replace the pilot bearing at the same time.
Post Posted: Wed May 26, 2010 11:05 am
spigot?
Post Posted: Wed May 26, 2010 11:08 am
Benz2369 wrote:
spigot?
No thank's, I just ate.. :roll:
Post Posted: Wed May 26, 2010 10:39 pm
Benz2369 wrote:
spigot?
yea same thing.
Post Posted: Thu May 27, 2010 12:50 am
yeah will do that =]
thinking of doing breathers to the gear box and tranny.
i know the gear box has a little metal pipe sticking out to fit my hose over.
but what does the tranny have?
thanx again guys
ben
Post Posted: Fri May 28, 2010 12:53 am
found it. has a the same breather setup as the diffs.
just adjusted the clutch cable to see if that would make it at lest drivable (i'm not driving it atm) and now it squeaks on the way in and on the way out. not a very nice sound i can tell you that..... i don't get as much slip out of the clutch though.
should i drive it like it is :?
Post Posted: Fri May 28, 2010 5:05 am
Why not. I drove a f100 for 20k with the throw out bearing seized, would ust it to take off then clutch less the rest, including down shift..
Post Posted: Fri May 28, 2010 11:37 am
sweet its only that. (asked some other people too) i can drive it =]
yeah need the car tomorrow. didn't want to have to walk to work at 5 am...
Post Posted: Sun May 30, 2010 12:00 am
new clutch came in yesterday.
so i'm going to pull the flywheel out today.
hopefully its all back together b4 next weekend
anyone got how tight to do the flywheel and clutch with the torque wrench handy?
cheers
Post Posted: Sun May 30, 2010 12:54 am
I would be interested to see how you go with it, any problems or if it was easier then you expected.
Peter
Post Posted: Sun May 30, 2010 11:32 am
gear box is out and flywheel will go in for refacing tomorrow
so i will have a car again for the long weekend =] =] =]
here is a pic of the old clutch and the flywheel. you can see there has been some heat there....
Post Posted: Sun May 30, 2010 11:37 am
looking at the gear box i found a random hole that looks like it leaks oil.
cant think for a reason for the hole. anyone know what it is???
Post Posted: Mon May 31, 2010 10:16 am
no ideas? :(
Post Posted: Mon May 31, 2010 10:27 am
Benz2369 wrote:
no ideas? :(
I'll look up the manual tomorrow, one of the other jim driver's has one so thay may post it up before i get a chance..
Does it have a thread??
Post Posted: Sun Jun 06, 2010 11:58 am
clutch is all done =]
it's heaps better!
the pedal is a little heavier
it was a real pain getting the gearbox in and out..
in hind sight i probably should have just slid the gearbox back and then do the clutch with the gap.
clutch got a real workout at MOA this weekend.
very very happy
Users browsing this forum: No registered users and 193 guests
