It is currently Tue Jul 28, 2026 7:49 pm
Post Posted: Thu May 27, 2010 11:06 am
Gday guys Katie's vitaras has just started a bit of a problem when you turn the indicator on some times it works or some times it flashs slower then normal and then some times it just stays on with out flashin at all :?
Any ideas people??????????
Post Posted: Thu May 27, 2010 11:19 am
Flasher unit.
About 10 bucks from Supercheap.
I want my old sig back :(
Post Posted: Thu May 27, 2010 11:24 am
Ben_Sierra wrote:
Flasher unit.
lol u like supa cheap dont ya ben
but yer more hen lickely it would be the unit
dose it only happen when indicating one way or does it do it on both sides?
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Thu May 27, 2010 11:29 am
Happen left and right.....Where abouts do i find this flasher uint?????
Post Posted: Thu May 27, 2010 11:34 am
stick ya noggin under the dash with the hazzards on... it should be the thing going tick tick tick
Post Posted: Thu May 27, 2010 11:36 am
rofls ya beat me to it gus usualy on the left hand side i think
-indebt 4x4 club-
Post Posted: Thu May 27, 2010 11:37 am
give it a hit with something :lol:
Post Posted: Thu May 27, 2010 11:39 am
Cheers guys ill sus it out tomorrow after work
Vehicle: LPG 1.6 Sierra
Post Posted: Thu May 27, 2010 11:40 am
Under the dash, passenger footwell, behind the carpet, near the heater box - about the size of a D cell battery. Might be mounted to the firewall, or might be hanging loose.
Before replacing - try unplugging/replugging it... mine had the same problem and this got it working again. Has worked fine ever since.
Post Posted: Thu May 27, 2010 11:52 am
Yeah i was gunna try that
Post Posted: Thu May 27, 2010 11:55 am
My blinkers also worked without the flasher can... dunno how though.
Post Posted: Thu May 27, 2010 11:57 am
:lol: Are ya sure you unpluged the flasher uint?????
Post Posted: Thu May 27, 2010 12:09 pm
i think the vitara's might be on the drivers side.
Post Posted: Thu May 27, 2010 12:14 pm
Can't miss it - I even went to Repco and had the exact part in my hand, just short of loose cash at the time to buy (actually costs $25 if I remember right).
I know it sounds strange, but I pulled it off and the blinkers still worked. Plugged it back in and then the blinker speed corrected itself. Don't ask me how/why/what... I can't explain.
Post Posted: Thu May 27, 2010 8:34 pm
do you have speakers in the bottom of the dash joe? if so its behind the drivers side one
ive seen this few times and on mine as well, I would rip your column shroud off and give the switch a clean with contact clean as well before spending money
Post Posted: Thu May 27, 2010 11:44 pm
Yep speakers are down there ill give that a go too cheers bud
Post Posted: Sat May 29, 2010 3:22 am
Flasher uint it was had to try three different shops till i found one that had it in stock.
$30 and they fitted it too just cause im lazy :roll:
Post Posted: Sat May 29, 2010 4:39 am
You could allways pretend its a BMW and not use them at all...he he
Post Posted: Sat May 29, 2010 4:42 am
No no no.
thats the BOMB! 8O :lol:
Post Posted: Sat May 29, 2010 6:58 am
No no no.
Thats ok aslong as it goes off when Katies driving it and not me :lol:
Users browsing this forum: No registered users and 669 guests
