It is currently Thu Oct 29, 2026 4:07 pm
Post Posted: Wed Jun 16, 2010 8:09 am
hey all,
Ive gotta replace my rear wheel bearing tomorrow at work. im wanting to know wats is the quickest way and easiest way to do it ?
2''lift 31's twin locked & 6.5s
Post Posted: Wed Jun 16, 2010 8:10 am
Grinder and chissel. Just don't cut into your axles.
Post Posted: Wed Jun 16, 2010 8:14 am
ok then kool so just cut them down enuf and then chissel it off.?????
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Wed Jun 16, 2010 8:17 am
NOTE you might like to wear safety glasses during this stage. They some times like to jump
Post Posted: Wed Jun 16, 2010 8:19 am
Yeah there is a bearing and a retaining ring. You cut through the retaining ring the best you can then smash it appart with a chissel. Then attack the bearing.
As Rhino said, wear some safety gear.
Post Posted: Wed Jun 16, 2010 8:20 am
Yep, that's the best way. The backing plate will prevent most presses being able to remove them. Just be careful not to nick your axles
Post Posted: Wed Jun 16, 2010 8:21 am
ok then yeh we did a hilux one yesterday at work. oh and wat bout puting them back on ?
Post Posted: Wed Jun 16, 2010 8:22 am
Use a press if you can.
Post Posted: Wed Jun 16, 2010 8:24 am
hey all,
What didn't you believe me when I told you this arvo, thats how you get them off.
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
umm we got one of them small work shop press not sure if it would be tall enuf but. and dont have a tube that would go over the axle
Post Posted: Wed Jun 16, 2010 8:26 am
I've used a piece of pipe to install them
Zuki
Now just drive i
Post Posted: Wed Jun 16, 2010 8:27 am
If not a 2 to 3 ft length of 32nb pipe, slide it over the axel & use that as a slide hammer..
Post Posted: Wed Jun 16, 2010 8:28 am
When fitting them back on, the bearing will slip all the way to the machined shoulder at the end. Put the axle between two heavy steel plates or a bearing plate and have the end of the axle/ backing plate up in the air. Shift the bearing plates against the sides of the axle so that the bearing is onto of them, and press down on the centre of the axle. Repeat for the retainer.
ok then
Post Posted: Wed Jun 16, 2010 10:58 am
And make sure you tighten the 4 little nuts on the retaining plate :wink: :oops!: pompoms
Post Posted: Wed Jun 16, 2010 11:00 am
And make sure you tighten the 4 little nuts :wink:
:rofl: :rofl: :rofl: :rofl: :rofl: :thefinger:
Post Posted: Wed Jun 16, 2010 12:20 pm
Yeah yeah.
And your driveshaft bolts, and if your rear calipers are making heaps of noise its probably because the bolts are 3 full turns away from being finger tight 8O :oops: :D
.......On both sides :oops: :oops: :oops:
Post Posted: Thu Jun 17, 2010 8:02 am
all done thanks for all info guys.
Users browsing this forum: Google [Bot] and 279 guests
