[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
benchez
Joined: Fri Apr 30, 2010 1:39 pm Posts: 120 Location: St Helens
 Posted: Fri Jun 18, 2010 5:20 am |
I have lost fluid in the last few days and after having a look today, noticed it leaking around the bottom of the water pump where it bolts to the block. Does this mean dead pump or just a blown gasket? Easy job or PITA? I have to change an inlet manifold gasket and do my carby gaskets in the near future, so easier to wait and do it all at once? Advice please!
_________________ 92 Sierra Hardtop, 2" OME Lift, 30" Maxxis Mudders
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Jun 18, 2010 5:25 am |
What engine? Leak from pump usually means dead pump. If it's a G series motor then you need to remove timing belt. All the info you need is in the download section.
benchez
 Posted: Fri Jun 18, 2010 10:49 am |
Motor is a G13. Water looks to be leaking around the bottom of the pump.
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Fri Jun 18, 2010 10:56 am |
99% sure it will be buggered. It's a cheap fix at least
_________________ Shep is a closet jimny lover!!!!
royce
 Posted: Fri Jun 18, 2010 11:05 am |
youll probably find its coming from teh drain hole in the pump once you get teh pulley off, meaning the pump is stuffed
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Sat Jun 19, 2010 1:00 am |
I had the same thing last week... A new pump was only $50 (and I didn't really shop around).
The timing belt does need to come off but still its not a massive job...
_________________ I want my old sig back
benchez
 Posted: Sat Jun 19, 2010 6:01 am |
Yeah The timing belt was easy, I did only about a week ago! If only i'd known! Oh well will just have to keep topping it up til I have my gaskets as I need to do both manifolds (exhaust needs to be changed over as it's cracked) as well as both carby mount gaskets. Some eBay shopping followed by a day under the bonnet. Awesome, it's just started getting really cold down here!
[ 7 posts ] |
Users browsing this forum: Google [Bot], winchzook and 222 guests
