It is currently Wed Oct 28, 2026 8:44 pm
Post Posted: Wed Jun 23, 2010 1:22 am
What is the part called- It connects the dizzy cap( and points) to the engine through a manifold of some type?
The reason I ask is that my 93 sierra is running bad after not being started for a year and now the engine oil is leaking from the bottom bolt of this part.
If not its my head and I really hope not!
Thanks in advance for any help!!!
Post Posted: Wed Jun 23, 2010 1:54 am
That is a really, really, really bad description but I think you mean the distributor housing.
It is a 1993 sierra so I am assuming it is a 1300, if so the housing is held on by 3 bolts and has an "O" ring seal.
If it is a 1 litre (maruti) then the housing is held on by 3 bolts and has a gasket seal.
This will not account for your engine running bad but can account for oil leaks.
Vehicle: '92 Sierra
Post Posted: Wed Jun 23, 2010 2:22 am
x2 for the distributor housing o-ring. Mine is leaking right now. As did the one on my old engine.
Post Posted: Wed Jun 23, 2010 2:27 am
I pulled mine apart and put back on with gasket glue, but now it wont kick over? What tha?
Post Posted: Wed Jun 23, 2010 2:36 am
Did ya put it back with the rotor button pointing the right way? Or just stick it back in...
I want my old sig back :(
Post Posted: Wed Jun 23, 2010 2:54 am
Just put it back. Doesnt sound good. What do I do?
Post Posted: Wed Jun 23, 2010 3:02 am
Take the dizzy out, turn the engine by hand to Top Dead Centre on number 1, put the dizzy back in so the rotor faces the number one lead.
Post Posted: Wed Jun 23, 2010 5:35 am
Thanks guys just found out what TDC is and all makes sense now
Users browsing this forum: Google [Bot] and 278 guests
