It is currently Tue Oct 27, 2026 12:32 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Vehicle: 98 Maruti
Post Posted: Wed Jun 23, 2010 7:23 am
iv finally given up (for now) at getting my stuck fill plug out of my gearbox on my GV, but it deferentially needs a oil change so im thinking if i drain the oil and measure out the right amount could i just pour it in through the gear stick hole?
Last edited by experament-u2 on Thu Jun 24, 2010 10:08 am, edited 1 time in total.
Post Posted: Wed Jun 23, 2010 7:42 am
yes
Post Posted: Wed Jun 23, 2010 7:51 am
ajsr wrote:
yes
x2, slowly tho, I've done it heap's of time's.. :P
Post Posted: Wed Jun 23, 2010 11:11 am
Owned my old zook for over 12 years, even with different gearboxes could never get the filler out..been filling thru the gear stick hole forever :))
Post Posted: Wed Jun 23, 2010 11:26 am
was just thinking "sweet might do that next time"
but jimnys have a funny gear stick setup =[
Post Posted: Wed Jun 23, 2010 11:31 am
I had to fill front diff thru breather for ages, too. had a small funnel, and a lot of patience :)
Can help a lot if you warm the diff oil first.
Vehicle: 98 Maruti
Post Posted: Wed Jun 23, 2010 1:06 pm
thank you gentlemen, my gearbox will soon be all nice a lubed up :)
Post Posted: Thu Jun 24, 2010 9:36 am
Since when do territorians change the oil in anything? :P
I had to drain the oil out of my transfer through the front driveshaft hole :oops:
Post Posted: Thu Jun 24, 2010 9:58 am
:lol: :lol: I love the look on apprentice's face's when that happens.. :lol: :lol: :lol: :lol:
Vehicle: '92 Sierra
Post Posted: Thu Jun 24, 2010 10:05 am
Took my gearbox out twice before finally deciding its not worth trying to get it out full. I love the taste of VMX80 in the morning.
Vehicle: 98 Maruti
iv got a problem
just tried to fill my gearbox up, drained the oil and pulled the gear stick out
:( started putting it in slowly and nothing it started pooling in the collar bit wear the gear stick goes :( :( :( not going into the gearbox
whats the go
Post Posted: Thu Jun 24, 2010 10:07 am
being new to vits, I did that accidently during a diff job :roll:
never happened with the sierra
Post Posted: Thu Jun 24, 2010 10:15 am
experament-u2 wrote:
iv got a problem
whats the go
never heard of that b4, may be an air lock, try poking summit to break the seal ?? just guessing, no idea
Vehicle: '92 Sierra
Post Posted: Thu Jun 24, 2010 10:19 am
Could it be something like you removed the gear lever while it was in gear?
Post Posted: Thu Jun 24, 2010 10:20 am
iv got a problem
whats the go
8O It should have a flow back.. 8O
Follow the selector forward a lil, you'll see 4 12mm bolt's in the top of the box, you may have to take the selector box off & pour it in there..
I could of sworn it had a flow back.. 8O
Post Posted: Thu Jun 24, 2010 10:21 am
iv got a problem
whats the go
Its a 1.6 GV would that make a differance :?
Post Posted: Thu Jun 24, 2010 10:27 am
It should flow, has to have supply of oil for the selector's, so it need to get back again..
Vehicle: 98 Maruti
Post Posted: Thu Jun 24, 2010 10:36 am
iv got a problem
whats the go
i think its in gear so i will take it out of gear, i just hope it has flow back
Vehicle: 98 Maruti
Post Posted: Thu Jun 24, 2010 10:54 am
ok took it out of gear still nothing
i cant work it out
here a pic of my setup
Post Posted: Thu Jun 24, 2010 11:05 am
card board roll, over hole, blow into it, see if air flows thru, then you least know if oil can get thru, maybe gv is a greased rather than oiled gearstick.
Post Posted: Thu Jun 24, 2010 11:07 am
You may have to lower the box a bit, taking the mount out should be enough, & take the selector box off & fill it through there..
Post Posted: Thu Jun 24, 2010 11:08 am
I've rolled em over & oil came out the hole.. 8O
Vehicle: 98 Maruti
Post Posted: Thu Jun 24, 2010 11:18 am
just tried giving the gearbox a blow job, seams liek air is flowing through but i cant be sure cause air escapes around it il try again sealing it
tried a bit of hose in the fill plug blowing up and that feels liek air is flowing
:( still not sure where my selector box is
Post Posted: Thu Jun 24, 2010 11:25 am
have no idea if it is cold up there at night, but if so, warm the oil first, in a hot bath, or similar, the oil may be too thick to flow werll
Post Posted: Thu Jun 24, 2010 11:29 am
:P your thinker.. :P
Post Posted: Thu Jun 24, 2010 11:34 am
Glad ya spelt it that way, or is it a typo :D
Post Posted: Thu Jun 24, 2010 11:39 am
:? Um. :?
Post Posted: Thu Jun 24, 2010 11:44 am
steknig wrote:
:? Um. :?
haha darwin gets down to about 22degc :lol:
Post Posted: Thu Jun 24, 2010 11:49 am
OK. Was a wild guess. NT is a big place :))
I have been frozen in the outback at night regularly, away from coast, but that wasn't this time of year.
Post Posted: Thu Jun 24, 2010 11:50 am
it would be down to 0deg near Alice
Users browsing this forum: No registered users and 196 guests
