It is currently Wed Oct 28, 2026 10:04 pm
Post Posted: Thu Jun 24, 2010 10:51 am
My Lwb 93 vit has an erratic idle, it can do it hot or cold, and doesnt do it all the time :? It can sit on 2000 rpm and then drop then go back up and at one time was like a pulse.
Anyone know the cause?
Post Posted: Thu Jun 24, 2010 11:27 am
more than likely idle air control valve. try cleaning it with throttle body cleaner or similar.
Post Posted: Thu Jun 24, 2010 11:34 am
And that bit is where? :lol:
Post Posted: Thu Jun 24, 2010 12:59 pm
just near the throttle body from memory.
try cleaning it with some throttle body cleaner or simila.
Post Posted: Thu Jun 24, 2010 2:12 pm
it could be a blocked EGR : http://bbs.zuwharrie.com/content/topic,27769.0.html
or the IAC: http://bbs.zuwharrie.com/content/topic,22023.0.html
http://bbs.zuwharrie.com/content/topic,87081.0.html
i'm not 100% sure how relevant those threads are as they are US based 1.6's
Vehicle: '92 Sierra
Post Posted: Thu Jun 24, 2010 9:40 pm
Is the 93 multi-point injected? I think that idle air control post above describes the wax pellet design that is used in the throttle body injected motors. i didn't think they made it into the multi-point ones. Whatever it is it must have one of those fast idle thingy-ma-jigs that bumps the idle when theres a power draw on the system like turning the head lights on. Try disconnecting this to rule it out.
Post Posted: Fri Jun 25, 2010 10:34 am
Mine is the same as the one pictured in this thread, might have to look at that pipe they say gets clogged up!
chop
Post Posted: Sun Jun 27, 2010 10:15 am
Well today i noticed the check engine light was on, dont think it had come on before but it is hard to see it during the day!
Maybe it was coz the car didnt like being north of the city :lol:
Post Posted: Sun Jun 27, 2010 10:19 am
The IFL can help lot's, some of the code's can take 30 cycle's to appear, so finding fault's not all way's easy..
Post Posted: Sun Jun 27, 2010 10:25 am
whenever mine does that I clean the throttle body with contact clean and usually find a loose hose somewhere and its right
the iac is controlled by the computer, for it to be switching that it has to be reading a fault somewhere
Post Posted: Sun Jun 27, 2010 10:41 am
IFL? sorry got my dunce on :oops:
Post Posted: Sun Jun 27, 2010 10:48 am
my GV used to turn the check engine light on from time to time - i ended up finding it was a loose connection in the engine bay that worked itself loose from time to time. Wasn't noticeable at all except the check engine light turned on.
Not that i'm saying the two aren't connected, just saying its a possibility.
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Mon Jun 28, 2010 12:31 pm
dont worry about it, if you were norf, that will do it to ya....just look what it does to the locals :wink:
Go Hard, Trailer Home
Post Posted: Tue Jun 29, 2010 8:40 am
That would put the check engine light on 8O
Been reading through this site http://www.kick-fix.com/ very good info, will be going through some of the fixes on here :wink:
Post Posted: Tue Jun 29, 2010 9:01 am
It's F*#ked Light. :roll: :P :P :P
Vehicle: 75 Cruiser
Post Posted: Tue Jun 29, 2010 9:12 am
did you check the error code?
your air flow meter could be stuffed, that's if you got one with your engine.
Post Posted: Tue Jun 29, 2010 10:08 am
it's bin a while now Steve... :rofl: :rofl: :rofl:
Post Posted: Tue Jun 29, 2010 11:26 am
Just found a crack in that resonator thingy to the side of the airbox, the thing that looks like a blob :?
Wondering if that wouldnt be helping the cause.
Post Posted: Tue Jun 29, 2010 11:32 am
the cracked blob wouldn't help the situation, smash some silicone or insulation tape on it & see if it fixes it.
Post Posted: Sat Jul 03, 2010 11:11 am
Royce, do you spray the pretty much the whole throttle body when you clean it?
I picked up some MAF cleaner and will give that a clean also, and i dont think i can get in to clean tge EGR pipes as i think my model has the tubes in the intake casting.
Users browsing this forum: Google [Bot] and 364 guests
