It is currently Sun Nov 01, 2026 9:47 pm
Post Posted: Sat Jul 17, 2010 7:59 am
Hi Guys
Just got some Skid plates for the Jimny from ODA, and want to install them myself.
Im not to sure how to go about it, or where to jack the car up, to start undoing the bolts. I'm not sure what type of tension is held in the control arm, and what will happen when I eventually unbolt it.
Also what could I use to make it easier to undo the bolts.
Cheers.
Post Posted: Sat Jul 17, 2010 8:01 am
ADO... is that dyslexic for ODA :lol:
Post Posted: Sat Jul 17, 2010 8:27 am
haha 8O
yep Im a spaz
fixed..
ADO = AUT DOOR ORTO
Post Posted: Sat Jul 17, 2010 9:12 am
Cheers.
rattle gun.
Post Posted: Sat Jul 17, 2010 9:15 am
brindog wrote:
ADO = AUT DOOR ORTO
spelt with an occa accent :lol: :lol:
might just be the slowest build on the forum...
Post Posted: Sat Jul 17, 2010 9:34 am
i would jack it up from the chassis and take all the weight off the axle. have the wheels a bees dick off the ground.
then do one at a time.
BUT i haven't unbolted the control arms. i'm just guessing by what i know.
it's what i would do anyway.
i wonder if i should get some of these... mine are getting the paint slowly sanded off. . . .
Post Posted: Sat Jul 17, 2010 9:37 am
use jack stands too!
Post Posted: Sat Jul 17, 2010 10:01 am
X10000000000000000
Post Posted: Sun Jul 18, 2010 9:00 am
Or the easy way would be to park on level ground hand brake on in gear, and use a big F$%ken spanner to undo the leading and trailing arm bolts at chassis end do one at a time, carefully push bolt out with long thin punch and or screw driver, install guard and put bolt back in you can push the wheels back or forward slightly to line up arm with chassis, I've replaced arms this way on my own its no big deal and no stress on control arm bolts when car is level.
Post Posted: Sun Jul 18, 2010 9:09 am
x2
dont jack vehicle up. leave wheels on ground. undo and remove the bolt, the control arm wont drop but may move up a bit. put the skid plate on and if you have trouble getting the bolt back in then put a screwdriver in the other end and lever it until you can slide bolt through. i wouldnt worry bout torque settings, just do up tight.
Post Posted: Sun Jul 18, 2010 8:28 pm
ok cool thanks guys, I'll have a crack at it, sound easy enough, only thing hard, is how tight they are, probably use a lever on the spanner.
Thanks again
Post Posted: Sun Jul 18, 2010 10:29 pm
Surely they would come with some kind of fitting instructions that would spell out teh safest way to fit them? mucking around with bits that hold the car up can get messy if you dont take your time and keep your fingers out of places that might squash them
Post Posted: Mon Jul 19, 2010 7:59 am
If you can read Thai :roll:
Post Posted: Mon Jul 19, 2010 10:11 am
Why not ask ODA himself?
2002 SWB GV
Lifted and Locked
Post Posted: Wed Jul 21, 2010 6:31 am
The bolts where way to tight to get off, so I ended up getting a mechanic to do it. I don't have the right tools. :(
Some pic's are in my build thread.
http://auszookers.com/index.php?name=Fo ... c&start=30
Post Posted: Wed Jul 21, 2010 7:36 am
good to see Tim, stepping in & supporting the products he sells... nice customer service ODA :roll:
Post Posted: Wed Jul 21, 2010 7:41 am
no he did help me, sent me a PM
Post Posted: Wed Jul 21, 2010 8:23 am
ahhh cool, not sure why he didn't post it in the thread for anyone else that goes to install them...
Post Posted: Thu Oct 07, 2010 8:15 am
Fitted mine today, would have taken about 1 hr all up (should have been a lot less but some persuasion was required on the existing brackets as a couple were pretty messed up.)
Notes.
Tools required 2 x 17mm spanners, 2 x 19mm spanners, old fukd'd large screw driver to line bushes up with brackets. (torque wrench but I am pedantic)
No need to jack car up as it will make the arms drop further when released, but a jack can be handy for raising the lateral arm to line up the bushes with the brackets when putting the new bolts in..
The kit is not just the plates, it comes with 4 x longer bolts, 8 washers, 8 spacers and 2 thinner bolts nuts and washers which I suspect may have a purpose on a later jimny.
During the install I rang Tim re the 2 extra bolts in the kit and he was very helpful.
Be prepared to do some panel beating if your brackets have already been bent over, but otherwise it was an easy job but does require a bit of muscle, having said that I have access to a hoist but did it on the driveway.
Geoff
Post Posted: Thu Oct 07, 2010 3:31 pm
Inox is good for fused bolts - especially if you can drown it then leave it overnight as it penetrates. WD40 Ok too, but not as good. Otherwise heat can work (like real heat gun, not just hairdryer) or just grunt - mechanical advantage through an extension arm on the spanner helps.
Users browsing this forum: Google [Bot] and 60 guests
