It is currently Wed Oct 28, 2026 11:28 am
Post Posted: Tue Jul 27, 2010 10:13 am
Can anyone tell me how to get the green CV housing off the driver side of the GV diff? I have tapped the shaft out of the other side, but still can't get the housing apart.
[img][IMG]http://i867.photobucket.com/albums/ab235/mick70b/IMG_0007.jpg[/img][/img]
Sorry it's not downsized, I'm having trouble resizing and uploading images
Virgil the Vitara
SV620 Estate
Post Posted: Tue Jul 27, 2010 10:17 am
pry it out with a flat bladed screw driver, be gentle :wink:
EDIT: in between the housing & the CV cup.
Post Posted: Tue Jul 27, 2010 10:19 am
put the bolts back on your centre. Its likely the axle is binding in the centre.
Post Posted: Tue Jul 27, 2010 10:25 am
okay thanks guys I will try that ... tomorrow, I was playing with a big screwdriver as you said but I have been VERY gentle because I wasn't too sure what I was doing :?
Virgil the Vitara
SV620 Estate
Post Posted: Tue Jul 27, 2010 10:45 am
nice spotting, i didn't even look at the picture :oops:
Post Posted: Wed Jul 28, 2010 10:35 am
I've been trying with a big flat screwdriver and have only got it to move about 6-8mm ? :?
Virgil the Vitara
SV620 Estate
Post Posted: Wed Jul 28, 2010 10:41 am
did you bolt the diff centre back in?
Post Posted: Wed Jul 28, 2010 11:35 am
6 to 8mm is just the spline, you will need to put a lil more force behind it, i've had to flog pry bar's with hammer's to get em out..
& as Mr Fat said, the center loose like that will put pressure on the shaft. not allowing it to come out..
Post Posted: Wed Jul 28, 2010 12:10 pm
Yep the bolts are back in, just didn't know how hard I should go with it, will have another go with a bit ore oomph .... :wink:
Virgil the Vitara
SV620 Estate
Users browsing this forum: Google [Bot] and 321 guests
