It is currently Thu Oct 29, 2026 7:50 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page 1, 2, 3  Next
Vehicle: 2012 Jimny, Locked both ends
Post Posted: Mon Aug 16, 2010 12:03 am
hi all
just looking into a few option for the zook in the way of getting some more km's between filling up.
but first i want to make sure my engine aint too thirsty compaired to others.
currently with my webber im gaining about 350kms before i need to fill up. and thats when she is almost dead empty, so to fill up she takes 38L of the 40L tank!
is this sort of milage average for a zook?
i ask as my engine has done about 240,000 and is starting to show her age a little bit, and i dont want to waist time of moding tank mounts, jerry cans etc if i could spend a bit of time on refreshing my engine and gain a couple of ponies and milage at the same time.
thanks
Jordan
Post Posted: Mon Aug 16, 2010 12:23 am
Search and you will find.
http://auszookers.com/index.php?name=Fo ... t=per+tank
Post Posted: Mon Aug 16, 2010 12:32 am
That mileage is about average 10.8L/100km
If you want longer range without changing fuel tanks or carrying jerry cans, change the way you drive.
The easiest way to save fuel is to drive at 80km/h max, and you will find your economy is much better, and even long drives only take 15-20 mins longer.
Or slip stream trucks (not very safe)
It is the terrible aerodynamics which give the zooks poor highway fuel economy. Remembering drag is proportional to velocity squared.
Trips may take you a little longer, but you are saving a heap of money and driving is less stressful.
If you did sit at the speed limit and spend more on fuel, the time you saved during the day would probably have been wasted by sitting infront of the tele or on the computer anyway.
Vehicle: '94 suzuki maruti
Post Posted: Mon Aug 16, 2010 7:07 am
time spent watching tv is never wasted!!!!
i get about 330km running the tank to dry, but my speedo is more than 10% off, im actually doing 100km/h when it reads 88km/h. so going off that, i get maybe 360-370km per tank assuming im babying it...
225,000km on the clock, never rebuilt.
Post Posted: Mon Aug 16, 2010 7:37 am
10-12ltr/100km
thats running 31's 4inch lift <-- yes lift does matter and a efi GTI motor, and that is moataring along, also tassie isnt flat!
Vehicle: jimny
Post Posted: Mon Aug 16, 2010 8:16 am
hmm click here for easy calculator
http://sikls1.v8owners.com.au/index20.html
mt lwb gets approx 10.26 i think per 100km.. stock with no roof so it has a little drag and thats going from wollongong to helensburgh, up a mountian range
Vehicle: 93 Sierra
Post Posted: Mon Aug 16, 2010 10:54 am
I get 11.5L/100km normally ... 13.5L/100km offroad and towing unladen trailer ... 15.0L/100km towing laden trailer :D
Slipstreaming trucks isn't that bad really. I usually call them on the UHF and ask if they mind me tucking in behind until xxxxx (usually the next roadhouse for a refill...) and I've not had one yet who had a problem with it. Just don't stick *too* close ... you should be able to feel the tail end of the draft by the slight sideways push and pull you'll get in the eddies - keep just ahead of this (about 30m for a road train) and you'll be fine. That gives you about 1s of reaction time assuming you can brake at least as quickly as the roadtrain which is pretty likely!
Post Posted: Mon Aug 16, 2010 1:13 pm
I'm getting 855-870km per tank. (83L tank) :D
Vehicle: LPG 1.6 Sierra
Post Posted: Tue Aug 17, 2010 11:18 am
How much does engine mileage (ie - i've got 220K on the clock) affect the outcome here? Will a rebuilt engine be noticeably more efficient than my old motor?
I'd also like to know what people with carby 1.6 conversions are getting from their sierras/vits
Post Posted: Tue Aug 17, 2010 12:02 pm
will let you know on that one, i had a 230K G13B in mine that has just bit the dust. it is being replaced with a 57K G13B out of a barina. It will have more power and hopefully a bit better fuel efficiency
Post Posted: Thu Aug 19, 2010 2:52 pm
That's a cool link eldo, I thrashed my Vitara around town this week & got 12.6l per 100 kms, I might try to drive it a bit more sensibly & see what I get.
Post Posted: Thu Aug 19, 2010 3:17 pm
70L Long Ranger tank
1.3L 4K Corolla Engine +5Sp Box
~4000RPM @ 100km/h
And i could drive from Newcastle to Melbourne on a single tank
Not sure if this info helps :D
Post Posted: Thu Aug 19, 2010 8:08 pm
1.6 carby motor, 30's, on a badly tuned sierra carb and i can get anywhere from 300 to 370km on roughtly $35. All depending on how and where i drive, my car hates trips into town it chews the fuel that way.
Post Posted: Fri Aug 20, 2010 12:40 am
~4000RPM @ 100km/h
:roll: but how many kms are you doing to your 70L
Post Posted: Fri Aug 20, 2010 12:41 am
:roll: but how many litres are you getting for your $35, you do realise that the price of fuel changes daily? :lol:
Post Posted: Fri Aug 20, 2010 12:45 am
860kms on 83L = 9.53L/100km
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Fri Aug 20, 2010 12:52 am
270km to a full tank (37 litres ish - dinted)...
Go figure? 235's and a rebuilt engine with 11,000ks on it.. I think i just need to take it a bit easier on the throttle maybe...
Subi + Suzi = Best of both worlds!
Post Posted: Fri Aug 20, 2010 12:56 am
13.7L/100kms
Click on Eldo's cool milage calculator
Vehicle: 1987 sierra tray back buggy
Post Posted: Fri Aug 20, 2010 1:22 am
13.7L/100kms
shit boy my hilux gives better economy than that and thats driven hard changing at 6000rpm generally trying to uses as much fuel as posible
Post Posted: Fri Aug 20, 2010 1:27 am
11 - 12 ltrs p/100kms with 1.6 baleno motor
6:5 gears, 4.1 diffs and 31's
Post Posted: Fri Aug 20, 2010 1:48 am
Normally around 260 - 280 kms per tank, motor is running a bit rough though.
95 Sierra, SPOA, 33 JT2s, 5.12s.
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Fri Aug 20, 2010 1:55 am
32/36 DGV 5a Weber progressive two barrel carb
tuned length extractors 2 1/4" inch straight thru exhaust
235's stock gearing
I'm getting close to 800 k's a tank driving from Perth to Kal sitting just under 100Kpm which is more like 110 with the tyres
Mind you with Camo paint I might go further :rofl:
I have issues
What are you looking at
Vehicle: '94 Stockman Trayback
Post Posted: Fri Aug 20, 2010 2:02 am
8.5L per 100km
Stockman 1L
Post Posted: Fri Aug 20, 2010 5:34 am
13.7L/100kms
Yeah I have foot flat to the floor allot of the time aswell. It is running a bit rich though an the trip meter would be out because of the bigger tyres. Speedo is out by about 8%.. but yeh, still pretty crap for a 1.3l engine in a 900kg car lol
Post Posted: Fri Aug 20, 2010 6:36 am
Myles wrote:
13.7L/100kms
Think your carby needs a little love :D
Post Posted: Fri Aug 20, 2010 7:15 am
what isnt 10-11lt per 100 good enough for you?
sierra's are probably one step more areodynamic than a house brick or shipping container.
live with it tight arse or buy a corolla :thefinger:
Post Posted: Fri Aug 20, 2010 8:21 am
Nah it never used to bother me, just sucks when I'm trying to save $250 of my $300 per week wages and my car costs me $60 a week in petrol to go to school lol. Also my best mates 93 barina gets like 500ks to a 40l tank so he allways pays me out about it lol.
Post Posted: Fri Aug 20, 2010 8:26 am
Myles wrote:
13.7L/100kms
and the engine judging by the oil that was in the batcave
Post Posted: Fri Aug 20, 2010 8:34 am
Myles wrote:
Nah it never used to bother me, just sucks when I'm trying to save $250 of my $300 per week wages and my car costs me $60 a week in petrol to go to school lol. Also my best mates 93 barina gets like 500ks to a 40l tank so she allways pays me out about it lol.
You get paid out by ya best mate who drives a Barina
What's her name :rofl:
I have issues
Post Posted: Fri Aug 20, 2010 9:03 am
hey i drive a 94 barina! a purple one:p
but i only drive it when its cold so i can have the heater
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 144 guests
