It is currently Fri Oct 30, 2026 10:30 am
Post Posted: Sun Aug 29, 2010 4:13 am
my shitbox has developed a bit of an issue.
the first time it happened was around 2 months ago and worked fine up untill yesterday.
turn the key to on and all the dash lights come on, turn to start and then nothing. no click, just nothing. then the dash lights wont come on.
after a bit of jiggling fuses and just poking bits the dash lights will come on and it may start but the cycle may start again.
i have found a melted fuse for the thermo fan, not blown but the plastic is actually melted. i rewired with new fuse holder and relay.
also the relay for the driving lights was hot to touch so i have removed all the driving light wiring.
no difference.
so i disconnected every accessory including the second battery.
no difference.
disconnected the starter motor and now the dash lights work reliably.
starter motor works fine if i use a wire straight from battery to the starter solenoid.
will wiring a relay in like a clicky starter fix do the job even though the starter has never had the clicky problem?
what the fuck is going on?
Post Posted: Sun Aug 29, 2010 4:35 am
fuseable link on the main battery?
thats what mine was.
good luck
Post Posted: Sun Aug 29, 2010 5:14 am
Check and clean all earths.. And as AJSR said check your commectioms on the battery + as well
A relay wouldnt be a bad idea... you may not have the clicky problem yet but your working with wiring that is over 20 years old.. So its just a matter of time
Post Posted: Sun Aug 29, 2010 5:15 am
haha i should have mentioned that i made a new fuseable link as that was my first thought as well.
Post Posted: Sun Aug 29, 2010 6:27 am
Main earth cactus ?
The negative side of things is a very overlooked creature.
Low drain, no need for any form of big wiring, but, when the starter is hit, huge drain, I replace all my negative lines with far far bigger wiring. All thoughts seem to run to positive, but without a same or bigger return, its fukd.
Post Posted: Sun Aug 29, 2010 7:26 am
yep dirty connection on a battery lead somewhere or the earth from battery to body
Post Posted: Sun Aug 29, 2010 7:54 am
found it :D the main earth that i had to the block had been torn out by a stick
of something and the little earth to the dizzy had melted.
Post Posted: Sun Aug 29, 2010 8:50 am
good luck
x2... I replaced my fuseable link on the main battery with a 30amp water proof blade fuse. I am running a Falcon alt as well.
255 characters
Post Posted: Sun Aug 29, 2010 8:51 am
:P
damn sticks... burn em.... burn em all!
255 characters
Post Posted: Sun Aug 29, 2010 10:58 am
So does a 30 Amp fuse work well with a 100 or 110 Amp Alt, or are you forever replacing the fuse?
Post Posted: Sun Aug 29, 2010 1:51 pm
come on somebody has to ask how my motor was earthing with one earth burnt out and the other broken.
i think it was through my awesome exhaust mount.
peaceout
Post Posted: Sun Aug 29, 2010 1:53 pm
:rofl: mulit function mount Armsup
Post Posted: Mon Aug 30, 2010 7:06 am
Works very well... all the other original cabling is still in place.. I fitted a thicker starter battery cable from alt to Batt as well. The orginal cable from the alt to the batt kept blowin the 30 amp fuse though but when I added the thicker one it stopped blowin.
255 characters
Post Posted: Mon Aug 30, 2010 7:08 am
peaceout
geeesss hydralic suspension and all!
255 characters
Post Posted: Mon Aug 30, 2010 7:16 am
peaceout
bladoath mate, its got all the flash modern stuff. :D
Vehicle: '94 suzuki maruti
Post Posted: Mon Aug 30, 2010 12:16 pm
found mine like that. tried to replace it, but i couldnt undo the screw on the firewall to replace the wire. fixed it by running a wire direct to negative terminal on battery. :lol:
Post Posted: Mon Aug 30, 2010 12:22 pm
i had a strange one not long ago..
no fuel pump, no driving lights, no thermo.. every thing elce was fine...
turned out chassis wasnt earthed... no idea how it earthed b4 but one day what ever was earthing it... well stopped.
Post Posted: Mon Aug 30, 2010 9:27 pm
Speedo, clutch or accel cable could do it too.
Post Posted: Mon Aug 30, 2010 9:52 pm
mine did that once. eventually fried the cable in position and jammed it on at at about 3/4 throttle. luckily in my driveway...
Post Posted: Mon Aug 30, 2010 10:47 pm
All electrical things should be earthed back to the battery, not the body. Fuel pump excepted.
Post Posted: Mon Aug 30, 2010 11:17 pm
No they shouldnt, but the body should have a decent lead from it to the battery negative
Post Posted: Mon Aug 30, 2010 11:23 pm
Yea ok, true, but if you look at all the stock electrical set ups, all are earthed back to the battery.
I used a piece of 300amp welding lead to earth the body from the battery, no more gremlins.
Post Posted: Tue Aug 31, 2010 1:24 am
Sierras have a multitude of loom earth points onto teh body and most notably the dash support bar!!!
Post Posted: Tue Aug 31, 2010 1:35 am
Royce, the only earth point I had on suziblu, that was 100% bog stock when I got her was a thin wire, can't remember, about 2mm from negative to the body just next to the terminal.
This melted and caused funny things to happen.
It was you that answered the problem, I had added spottys and a thermo, both earthed to the body, ( i recon as this caused the melting of the earth line), I have since researched a bit, and changed the negative sides to the battery and also the very heavy duty earth strap. Dunno if you can remember, one of the things happening was when I turned high beam on, the temp gauge would instantaneously rise to the top of the marks.
Seems to be fine now.
Post Posted: Tue Aug 31, 2010 1:52 am
This clicky starter problem everyone is talking about. i totally have that! is there a noobcad diagram of where to put this relay and the type of relay to use?
i've searched but on these work computers, its dialup speed and nothings working out for me.
ps... unless its a headdeck, amp and subz.. i don't make a habbit of touching wires... i have set cars alight trying to do simple things before. So if it looks even remotely difficult i will have to get someone else to do it.
weaves
Post Posted: Tue Aug 31, 2010 2:27 am
weaves
i am working on a article today. :wink:
Post Posted: Tue Aug 31, 2010 2:46 am
Awesome.. thanks shep
Post Posted: Tue Aug 31, 2010 3:01 am
here ya go mate
http://www.auszookers.com/index.php?nam ... ic&t=14695
Post Posted: Tue Aug 31, 2010 3:25 am
Your a legend shep!
I've printed this off, and its simple enough, even i will be able to do it!
cheers weaves.
Post Posted: Tue Aug 31, 2010 3:37 am
no problems :D
Users browsing this forum: No registered users and 305 guests
