It is currently Sun Nov 01, 2026 12:52 am
Post Posted: Sun Sep 26, 2010 11:41 am
hey guys is it better to leave the diff complete when welding on the diff or should i strip it completely?
Post Posted: Sun Sep 26, 2010 11:49 am
what part are you welding
if its perches complete is fine
Post Posted: Sun Sep 26, 2010 11:58 am
doing a 4 link so around the top of the pumpkin a bit and down the tube a little on the long side and then tabs iether end for links.
will small welds and letting it cool be alright?
Post Posted: Sun Sep 26, 2010 12:05 pm
I'd be inclined to strip & fit new seal's after the fab work's done..
You can get away with perch's if you watch the heat, but still better to strip em..
Post Posted: Sun Sep 26, 2010 12:17 pm
hmm, i would fit a blank center, to keep the housing braced as possible, then top up with liquid or just take your welding nice and slow...
Post Posted: Sun Sep 26, 2010 2:19 pm
take out the center and axles etc, put the whole thing in a jig with clamps and stitch weld the whole thing so you dont warp it =)
Post Posted: Sun Sep 26, 2010 10:22 pm
in a jig?? that means i have to make one...bugger
Post Posted: Sun Sep 26, 2010 11:51 pm
it'd only have to be a super basic one just to keep it straight - if you stitch weld it you're lessening that chance anyway... and dont forget to fish plate the whole thing as you go (mounts etc).
Oh - and another 2 tricks from my engineer - more than 50mm of weld per edge of a given mount (ie: if its a small tab, make it larger to get more weld), and try to keep thicknesses the same - dont weld 10mm plate to your 3mm chassis.
Users browsing this forum: Google [Bot] and 84 guests
