It is currently Sun Nov 01, 2026 3:31 am
Post Posted: Tue Oct 05, 2010 8:47 am
Im about to do a swap with a AW4 in to a LWB
The question i ask is how has anyone done the rear of the AW4 with a bearing and shaft/adapter?
Without ordering one of these?
http://www.trailtough.com/index.php?pag ... &Itemid=53
or
Im pretty sure joe blow has done it and maybe Gutless?
Anyone know of an aussie kit? Or just a bearing part number, etc?
Cheers.
Post Posted: Tue Oct 05, 2010 9:17 am
I used the trail tough adapter. You absolutely need it. The amount of play that is in the shaft without the transfer case supporting it is incredable!!
Post Posted: Tue Oct 05, 2010 9:50 am
correct me if i'm wrong but the tt sleeve is just a bushing?....no bearing? i'd be inclined to use a bearing. you won't need to cut and weld the tunel, thats the very hard way of doing it. if you are good with a hammer it can be streched out to look like factory, but be impatient and it will look like crap. and we are only talking about 10-15mm each side of the tunel, not a lot.
Post Posted: Tue Oct 05, 2010 9:52 am
Do the manual's need support on the output Joe??
Post Posted: Tue Oct 05, 2010 9:56 am
Joe do you do a kit?
I thought id read a few years back that you had made up something to suit for a few cars.
Post Posted: Tue Oct 05, 2010 10:01 am
if this is going into a maruti you can use the original cross member and fab up a new mount to run off it, if its a 1.3 it will have to be chopped. i have done a few of them that run a bearing, in a machined bearing housing bolted to a mounting plate that pics up 4 of the outer m8 holes, you don't need a full cover. my seal runs in the box and before my bearing housing so a full cover on the back is not needed. remember....maruti cross member can stay.
i can do a kit but realise mine has more components than the tt and is a little more expensive.
Post Posted: Wed Oct 06, 2010 7:18 am
Cheers! Thanks for the info!
Post Posted: Fri Oct 08, 2010 5:05 am
so refering back to Stekkys question above, does the manual 5 speed need this adapter to run without the transfer case, and if so can you use the auto one from lowrange?
Post Posted: Fri Oct 08, 2010 7:20 am
No Idea!
Im kinda thinking if your going down the track of a Vit gearbox you would only use an Auto and not bother with the Manual.
Post Posted: Fri Oct 08, 2010 7:26 am
meh for a road car i would prefer a manual
Post Posted: Fri Oct 08, 2010 7:42 am
In that case there is a lot of Manual J20a Vits and GV go through the pickles and manheim folwes damaged auctions.
Bugger all Autos tho, took me 2 years to find a good one with all the bits for the conversion that had not been killed in the crash!!
Post Posted: Fri Oct 08, 2010 10:32 am
Maybe we should start another thread, but from the one's I've had apart thay look to be supported enough for just a jack shaft, but testing that theory would/could ruin a box..
Post Posted: Fri Oct 08, 2010 10:57 am
They have a bearing at the end of the main shaft, so they are fine. The auto doesn't have this, hence the need to support the jack shaft.
Post Posted: Fri Oct 08, 2010 10:58 am
:P Cheer's!! :P
So when you wake up in the morning & the vit has no drive, wasn't me.. :wink:
Users browsing this forum: Google [Bot] and 335 guests
