It is currently Sat Oct 31, 2026 11:26 am
Vehicle: 95 Sierra Soft top
Post Posted: Thu Oct 07, 2010 8:11 am
Hey guys
Just want to know how does everyones sierras drive with bigger wheels on with a stock engine ??
My sierra is pretty slow and doesnt have much torque and that with 27" tyres, but ill be getting 31" soon so just want to know how other zooks cope with 31"s on ??
Cheers guys :wink:
Post Posted: Thu Oct 07, 2010 8:30 am
definitely invest in some transfer case reduction gears they are worth every cent.
inbits
Post Posted: Thu Oct 07, 2010 8:47 am
mine goes hard. 1.3 and 31s
tows a trailer no worries.
Post Posted: Thu Oct 07, 2010 8:58 am
And 6.5 gears?
I want my old sig back :(
Post Posted: Thu Oct 07, 2010 9:31 am
but with the gears in the t-case that means it will only work in 4wd, i was more thinking of road use with the big tyres and stock motor
There must be something wrong with my motor then, i have to be flat down on the pedal just to keep it at 90ks on the free way
is that normal for sierras ??
Post Posted: Thu Oct 07, 2010 9:34 am
sierra transfer gears also work in 2WD
mine lower highrange 2 or 4WD by 20% and low range by 180ish%
Post Posted: Thu Oct 07, 2010 9:47 am
What are the 6.5's like at 100klms does it scream ?
My Maruti build, Click WWW
Post Posted: Thu Oct 07, 2010 9:55 am
I run 31s with stock motor and gearing.......absolutly terrible!! 6.5s are in the mail. You will be sick of the bigger tyres in a months time. My advice is gearing, then if you want more power do the 1.6 vit motor.
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Thu Oct 07, 2010 10:01 am
31s with stock gearing means shitty driving and a very short lived clutch...
Gears are the only way.
Post Posted: Thu Oct 07, 2010 10:33 am
I had 31s wid 6.5s and drives nicely
Post Posted: Thu Oct 07, 2010 10:40 am
I'll have 33's with 1L transfer and 4.6 R&P. Should be almost stock gearing. And the 1.6 gives me some extra grunt :D
Post Posted: Thu Oct 07, 2010 10:46 am
about 3600rpm at 100kph. i would like 4000rpm at 100kph. :wink:
Post Posted: Thu Oct 07, 2010 10:51 am
Thats good!!
Mine sits at 4500 on 29's at the moment :?
Post Posted: Thu Oct 07, 2010 10:30 pm
hmmmmm so t-case gears is almost a must and a 1.6 aswell, thanks guys
oh does someone know the wieght diff in 31s to 27s or stock 205s cheers
Post Posted: Fri Oct 08, 2010 2:13 am
31s weigh about 18-20 kg each. 27s would be about 12kg i think.
Post Posted: Fri Oct 08, 2010 2:19 am
1.6 isn't really a must but gearing definitely is...
Vehicle: '94 suzuki maruti
Post Posted: Fri Oct 08, 2010 4:27 am
Thats good!!
wow... mine sits on 3500 on 28's... stock gearing though, and mines a later model that uses the 3.7 ratio in the diff
Post Posted: Fri Oct 08, 2010 5:19 am
mine sits between 3500 to 4000rppm at 120kph with 29's ;)
Post Posted: Sun Oct 10, 2010 8:08 am
Mine doesnt even get to 110 :( lol
Post Posted: Sun Oct 10, 2010 8:10 am
You can't get 110 on 27s with stock gearing?
Maybe you need to figure out whats wrong with your car... A good tune up is in order.
Post Posted: Sun Oct 10, 2010 1:36 pm
mines 1.6 though :lol:
Post Posted: Sun Oct 10, 2010 1:39 pm
You don't need a 1.6 to do 110...
Post Posted: Sun Oct 10, 2010 1:40 pm
a well tuned 1.3 will get you more then 110
Post Posted: Sun Oct 10, 2010 1:47 pm
Exactly
Post Posted: Sun Oct 10, 2010 2:15 pm
you need a jimny then. :lol: :lol:
Post Posted: Sun Oct 10, 2010 2:17 pm
i had a similar problem with the jimny a while back, couldnt go past about 90km/h, and the revs wouldnt go past about 3950 rpm. put in some injector cleaner and premium fuel and it solved that problem.
dont listen to me, i dont know much, seriously, but just a suggestion.
but i agree with the others, you should find out whats wrong with your car first before you play with the gearing.
Post Posted: Mon Oct 11, 2010 7:35 am
been there done that lol, engine runs smooth but the mechanic said the carby is bugged, and im not spending money on this if im get the 1.6 droped in, but its still slow :(
Post Posted: Mon Oct 11, 2010 9:09 am
Stock as A rock 1.3 with 6.5 transfers gets mine to 100 kmh at 3500 rpm and 110 kmh at around 4000 rpm. Top speed on a flat road is 130 kmh
Users browsing this forum: Google [Bot] and 482 guests
