It is currently Sun Nov 01, 2026 9:48 pm
Post Posted: Tue Oct 12, 2010 6:26 am
Guys,
just ordered a set of 4.9 transfer case gears for my 94, 1.3l sierra.
Thoughts? Keep in mind I'm only running 30", and planning to go to 31" ONLY in 18 months or so.
Cant wait!
Post Posted: Tue Oct 12, 2010 6:39 am
I've got 4.9 and 31" tyres and it suits me well. i used to have 6.5 and in my opinion 4.9 are better suited for up to 31 tyres than 6.5 gears. you just use 1st low more often than with 6.5. (1st low with 6.5 was more useful for steep descends than driving up the hill). there is many people who have 6.5 and 31" tyres in their zooks and they happy to.
Vehicle: WR250F/Jeep XJ
Post Posted: Tue Oct 12, 2010 7:08 am
hey Andy, Hows the bar going?
4.9s are bullet proof, been running them in my rig for years now. On 31s they will be perfect for victorian driving.
Why don't you come to a zook club meeting. it's on tomorrow night at AMRA Hall, 92 Wills St, Glen Iris (Melway 59 H7)opposite Glen Iris Station. 8:00PM start.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Tue Oct 12, 2010 8:18 pm
Dank,
BAr is due to be put on this weekend, as I have just pulled my 1.3 on the weekend.
I have a fair bit of work to do before end of nov.
I might drop in to the zook meeting, have a chat about a few things.
Will see how the day goes.
Thanks
Vehicle: '92 Sierra
Post Posted: Tue Oct 12, 2010 8:30 pm
Yep, running 4.9s and 31's and I think they're perfect. Perfect rpm on road and does all I need it to offroad.
Post Posted: Wed Oct 13, 2010 12:00 am
I'm buying the kit through cal off road.
When you install the gears do you need to also purchase a full rebuild kit ($115) to enable you to rebuild the transfer case?
How hard is it to install the gears?
Thanks
Post Posted: Wed Nov 10, 2010 5:07 pm
[COLOR="Black"]re: [url="http://www.mwdauto.com"][COLOR="Black"]transfer cases[/COLOR][/url][/COLOR]
from under the truck with a wrench we put it in four wheel drive, but when you reconnect the shifter it will not move the linkage. So we are thinking the bushings are siezed on the shaft. Does that sound right?
I have had a lot of good luck with these guys, [url="http://www.mwdauto.com"]rebuilt transfer case[/url], they have a bunch of salvage yards across the country
Post Posted: Wed Nov 10, 2010 6:41 pm
i have a rock lobester, so it's 4.9 and i run 3.9 diffs, and 29" tyres..... i wouldn't go any taller tyres wise, but i drive mostly rock....
Post Posted: Wed Nov 10, 2010 9:57 pm
yer put my 4.9's in last week from lowrange, im only running 29's and think they are unreal, absolutly improved the zook 10x mind you im also locked in the front. 31's next and i think it will be geared pretty much spot on for what i do :D
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Post Posted: Wed Nov 10, 2010 10:32 pm
I thought rocklobster was 4:1 :?
Ill probs go slightly against the grain here and say if you can find 5.14's they would be a slightly better option. I have the 4.9's on 30's with 3.7 diffs and could go that weeny bit lower offroad especially on the rocks. Any tcase lower gearset will point you in the right direction tho :P
Dan
Lil Foot!
Post Posted: Wed Nov 10, 2010 11:09 pm
I was considering running 5.38 Diffs and 6.5 Transfers on 33s.. But i'm just going to stick to the standard 3.7 ratio.. If i blow a few axles/cvs/centres ill think about Lux Diffs and i'll downgear them to the lowest.
Post Posted: Thu Nov 11, 2010 3:39 am
would 4.16 gears(rocklobster) with a 1.6l on 29's. also on 31's be any good? im thinking about doing a rocklobster
Post Posted: Mon Nov 22, 2010 7:41 pm
[url="http://www.mwdauto.com"]transfer case[/url]
try to get one with a CDL ('99-mid '01) and be sure to get shift lever if you don't already have one
I have had a lot of good luck with these guys, [url="http://www.mwdauto.com"]rebuilt transfer cases[/url], they have a bunch of salvage yards across the country
Post Posted: Mon Nov 22, 2010 8:03 pm
This is the second time you have posted a link to that company, and they certainly DON"T have a bunch of salvage yards across THIS country!! Why do you keep repeating the same thing, Mr SpamBot? And which Sierra cases have a Centre Diff Lock again, the '99-'01 was it?
Post Posted: Mon Nov 22, 2010 9:21 pm
Everyone says this, and fair call, but i still dont understand what the issue with not using 1st gear with 6.5's is? Whats the issue with using 2nd/3rd and 4th and still having the benefit of a very low 1st for desends and uber tech sections?
Post Posted: Mon Nov 22, 2010 9:33 pm
More trouble than it's worth considering you can get gears so cheap now.
Post Posted: Tue Nov 23, 2010 5:18 am
5ierra wrote:
What the issue with not using 1st gear with 6.5's is? Whats the issue with using 2nd/3rd and 4th and still having the benefit of a very low 1st for desends and uber tech sections?
There's no issue with running 31's and 6.5's so long as your terrain justifies it, otherwise it's just a wasted gear in the gearbox, and you're always in 4th low or swapping between low and high.
31's, 6.5's peak torque in 4th low: 21km/h.
31's, 4.9's peak torque in 4th low: 29km/hr
At 6000rpm the difference is 37 to 49 km/h
If your terrain justifies the use of 87:1 crawl, cool. I think 66:1 crawl is pretty usable with 31's though and would make for a less one-dimensional car.
I am very low geared (6.5's and 5.12's) which suits my motor, the weight of my car and the stuff I like to drive, but I have to use 4th low on greasy hills and that doesn't give me anywhere to go if I need more speed, I have to stop and use high range.
Post Posted: Tue Nov 23, 2010 10:02 am
Cheers steve, just thought i would raise the question becaus ei'm about to be running 6.5's and 3.7 diffs on 31 (next set of tires will be 33's... hence the reason i bought 6.5's)
Thanks very much steve.
Users browsing this forum: No registered users and 71 guests
