It is currently Sun Nov 01, 2026 6:28 pm
Post Posted: Thu Oct 14, 2010 7:09 am
Hi I'm looking at putting a g16 engine in my sierra and just wondering is there much difference between the G16a and the G16b performance wise. It will be mostly on-road for now but in the future maybe just for off-road.
Post Posted: Thu Oct 14, 2010 7:11 am
G16a is 8V carby, G16B is 16V EFI.
G16B has more power and torque (though the torque is a bit higher in the revs).
G!6A would be the easier conversion on account of not having to do nearly as much wiring.
I want my old sig back :(
Vehicle: 1987 sierra tray back buggy
Post Posted: Thu Oct 14, 2010 7:26 am
i think you will find that the g16b will produce more torque throughout the rev range than the g16a but will reach its peak later in the rev range.
go the b its not as hard as ya think and so nice.
Post Posted: Thu Oct 14, 2010 8:07 am
^^ what he said.
if you want to get out of it really cheap you can just bolt a 1.6 bottom end onto the 1.3 head too.
Post Posted: Thu Oct 14, 2010 9:29 am
Yes, most probably... I haven't seen the curves, but I know peak torque is a bit higher in the G16B (only by a few hundred revs though).
Really it comes down to the ease of conversion. The B is better, but the A is easier...
Post Posted: Thu Oct 14, 2010 9:34 am
from memory g16a peak torque is 3100rpm and g16b is 3400rpm? but the g16b has more, so you'd still have the same if not more torque than the g16a at the same rpm.
Post Posted: Sat Oct 16, 2010 9:28 am
[quote="alien"]from memory g16a peak torque is 3100rpm and g16b is 3400rpm? but the g16b has more, so you'd still have the same if not more torque than the g16a at the same rpm.[/quote
unless youve got a g16a with injection 8)
Post Posted: Sat Oct 16, 2010 9:30 am
i have had 2 LWB vitara's that had a 8V efi motor in them.
Post Posted: Sat Oct 16, 2010 9:47 am
ive got a swb 8v injection, never had a carbie to compare it to, but have had the 16v, much prefer 8v injection, pulls better low down.
Post Posted: Sat Oct 16, 2010 9:50 am
yeah they go hard, the ones i used were company cars :twisted:
Post Posted: Sat Oct 16, 2010 10:37 am
Really :? were they imports?
Post Posted: Sat Oct 16, 2010 11:10 am
narh, at least i dont think so, they weren't actually mine, they were just my work cars. :D
i always thought that the swb's were carby and the lwb's were tbi.
Post Posted: Sat Oct 16, 2010 11:28 am
Im 99.9% sure that all aussie spec 4 door vitaras were 16v efi, im probally wrong though :roll:
Post Posted: Sun Oct 17, 2010 6:26 am
There are also some imported G16A 16v fuel injected engines getting around. Just to mix it up a bit.
If you're going to do a conversion, I wouldnt bother with the carby 1.6. I had one then upgraded to the fuel injected 1.6. The EFI had loads more power than the carby with the advantage of being EFI :lol: Wont stall on hills, no more carby issues not idling.
The only extra work involved is wiring in a high pressure fuel pump and sorting out the wiring for the engine. An auto electrician should be able to sort the wiring out in a couple of hours, or you could get the wiring diagram and do it yourself. It aint that hard.
Member of C.O.R 4x4
Post Posted: Sun Oct 17, 2010 9:56 am
I had a imported shorty 1.6 8v TBI donk in my ute for a while. It was a very good motor. :wink:
Post Posted: Sun Oct 17, 2010 12:04 pm
i should put mine on a dyno some time... as its g16b bottom end and jimny top end. its VERY torquey - but because of the frankenstein engine i have no real figures.
Post Posted: Sun Oct 17, 2010 12:09 pm
i would like to see these, we have dragged of a few times and i always get left in the dust by miles, even with my g16b.....i got new leads :D time for a re-race lol.
Users browsing this forum: Google [Bot] and 472 guests
