It is currently Tue Nov 03, 2026 6:21 am
Post Posted: Fri Nov 05, 2010 8:47 am
about to put one in and the instructions say you need to drill a 81mm hole to be drilled...
81mm is a very odd size....
and can only get a 80mm or 83 mm hole saw.
how important is it to have the hole exactly 81mm?
thanx guys
ben
Post Posted: Fri Nov 05, 2010 8:49 am
Don't stress about it mate, when i put one on my vitara i used a holesaw that was a couple of mm bigger
Post Posted: Fri Nov 05, 2010 8:57 am
when i fitted my airtech snorkel i used the bigger size. it worked a treat :)
Post Posted: Fri Nov 05, 2010 9:00 am
yeah didnt think it would matter....
83mm i think will be best =]
but when your ripping a hole in you car you want to know its the right size i guess
thanx
Post Posted: Fri Nov 05, 2010 9:03 am
i'd use 80 then some nice smooth wet/dry to smooth it out and open it up a bit more before hitting with some rustguard to stop it rusting.
Post Posted: Fri Nov 05, 2010 9:42 am
good luck sanding a panel out 1mm with smooth wet & dry. :wink:
Post Posted: Sat Nov 06, 2010 9:45 am
83 mm worked fine =]
didn't expect the induction note to be so loud!
Post Posted: Sat Nov 06, 2010 9:50 am
pic's ?
might order one on monday
Post Posted: Sat Nov 06, 2010 9:30 pm
I put that on mine about a month ago. Its fits perfectly. :D
My build: Click WWW
Post Posted: Sun Nov 07, 2010 7:43 am
the induction noise is loud. but i reckon it sounds tops when ya put ya foot down
Post Posted: Sun Nov 07, 2010 7:59 am
everybody says they get the induction noise, i cant hear it at all.
Post Posted: Sun Nov 07, 2010 8:10 am
Neither can I!!!! D: But then again... I havent actually connected it up to the air intake.. :)
My build: Click WWW
Post Posted: Sun Nov 07, 2010 8:17 am
What are the airtech snorkels worth might i ask.
And how bad is the intake noise.
Mitch.
Post Posted: Sun Nov 07, 2010 8:33 am
mine cost me $460 bucks
the noise isn't bad.
sounds good =]
you can only hear it when your accelerating. any other time you cant hear much.
Post Posted: Sun Nov 07, 2010 8:41 am
I got mine for $80. ;)
And mine doesn't make a sound..... Yet.. :)
My build: Click WWW
Post Posted: Sun Nov 07, 2010 8:46 am
i dont really hear the induction that much - althoguh to avoid dust getting in i've flipped the head around, which made it FAR louder... especially when the right foot is on the floor, its like having a reverse exhaust pipe near your head.
it does sound cool though =)
Post Posted: Sun Nov 07, 2010 11:42 am
haha yes turning the head around makes it heaps louder!
pics of what it looks like as requested =]
Post Posted: Tue Jan 11, 2011 5:54 am
Howdy, wondering how hard it is to route the pipe throu the panel to the air box?
Thinking of ordering one and doing it myself.
Timmo
03 Jimny, 60mm Lift, 215 A/T BFG's, Dual Batts
Post Posted: Tue Jan 11, 2011 6:39 am
Two questions:
Have noticed any improvement in power or fuel, and does it create a blind spot where it is?
Paul
Post Posted: Thu Jan 13, 2011 11:42 pm
hermsie62 wrote:
Two questions:
Paul
no huge gain in power or fuel consumption...
and i guess there is a bit more of a black spot...
but I don't mind at all
biggest gain is not having your air box filled with mud which happened to me a few times b4 I got the snorkel. would be the only reason I would get one.
well I guess it keeps the dust out a bit too
Post Posted: Thu Jan 13, 2011 11:50 pm
Timmo
it goes straight into the air box from the outside.
there are no bends in the pipe work to worry about.
it really easy to do. =]
Post Posted: Thu Jan 13, 2011 11:52 pm
http://www.difflock.com/magazine/Worksh ... nter.shtml
if you read this it makes fitting it even quicker and easier.
Post Posted: Sun Jan 16, 2011 6:42 am
Benz2369 wrote:
hermsie62 wrote:
Two questions:
Paul
I can't see mine at all unless I move my head to the left or right.
Users browsing this forum: No registered users and 540 guests
