It is currently Wed Oct 21, 2026 6:14 am
Post Posted: Tue Nov 23, 2010 6:02 am
well i have been thinking i have a few $$$ in my transfer, might be worth running "the good oil" what is the redline shock proof like? i have sceen its around $60 a ltr is it worth it?
Phil
Post Posted: Tue Nov 23, 2010 6:25 am
8O
So WHEN your seal's leak, you can watch $120 worth of oil spill on the ground??
The pic's you post show you like mud, mud bugger's seal's & wheel bearing's, so I'd say no, no it's not worth it..
Post Posted: Tue Nov 23, 2010 6:32 am
steak_knife wrote:
8O
i think i have only ever replaced proberbly 2 seals in my trasnfer... however i have a new set here... so thinking i might pull her out, fit my new breather smash some new seals in and add the shock proof.
Post Posted: Tue Nov 23, 2010 6:46 am
I love it, all my cars run on it except the donks and they run Mobil 1
Its very light, 80-90 is the same weight as sae 30, less power drain, more power to the wheels for nothing except the oil cost.
like stekky says but, no leaks, very expensive otherwise.
Post Posted: Tue Nov 23, 2010 6:47 am
i used to own a 180sx and alot of my friends still own sports cars. never actually used it myself but my mate used it in his gearbox once that had a couple of crunchy gears and once he used the redline oil there was no crunching and he could shift alot quicker. like stekky said though mud + rubber seals + expensive oils = expensive and possibly a waste of time. but its your money...
Vehicle: '96 LWB trayback
Post Posted: Tue Nov 23, 2010 7:25 am
I've used it in my daily drivers box for ~ 10 years. The stuff is the best gear oil ever.
I don't see a need in a zook transfer personally, but if you want peace of mind go nuts.
Post Posted: Tue Nov 23, 2010 7:54 am
thats basicly it... i dont want to kill my 6.5s..
and at $50 a year cheep insurance?
Post Posted: Tue Nov 23, 2010 7:57 am
It is a lot cheaper on Ebay.....
Post Posted: Tue Nov 23, 2010 8:16 am
just saw that...
Post Posted: Tue Nov 23, 2010 8:35 am
I run heavyweight shockproof in my gearbox, and transfer. I chose heavyweight based on the increased torque loading of 6.5:1 transfer gears. IT flows like 90W but has the pressure point characteristics of 240W :shock:
Don't underestimate its ability to creep past seals. I think its higher viscosity tends to make it creep out of seals that mineral oil won't.
I lost a transfer case full of it out of a weeping rear output shaft seal. I didn't realise how little oil I had in my transfer until the input shaft bearings started to make grinding noises and a I had a transfer case full of mud.
Just my 2C. I'd run it, but as per the other comments, make sure you ensure all your seals etc are in top condition.
Post Posted: Thu Dec 15, 2016 6:30 pm
Bit of a grave dig but 6 years on what are people's opinions??? Is it width while insurance or is it like putting fuel additives in and no real gain other than self happiness. I brought some on a whim the other day. At $120 for 3.85l it's not more expensive than the Penrite full synthetic I usually buy which is close to $60 for 1.5l though it go's on sale at repco any time I go to bye it.
Users browsing this forum: No registered users and 120 guests
