It is currently Sun Oct 18, 2026 9:39 pm
Post Posted: Sun May 18, 2008 10:26 pm
how you going fellas, just wondering how hard is it to put a sierra t/cas to a vit box.. what needs to be done
spoa, lux diffs, 2inch suspension, 2inch body, 1.6
Post Posted: Sun May 18, 2008 10:34 pm
find antts members thread, he ran a vit box,vit transfer and sierra transfer
you need to cut the front output off the vit transfer and make up a mount to link the sierra transfer to teh vit transfer and a driveshaft
ends up pretty long as well
Post Posted: Mon May 19, 2008 12:10 am
i make these vitara transfers at half the length they were. joined to a sierra transfer with 2 uni shaft.
Post Posted: Mon May 19, 2008 2:29 pm
There's a mob in the states doing a similar thing but the 2 tcases are bolted together solid, no jack shaft. Could you do the same thing with your setup Joe?
Post Posted: Mon May 19, 2008 5:16 pm
can do...but ends up way too expensive. and if you ever have to remove the cases its a pita.
Post Posted: Mon May 19, 2008 5:18 pm
Post Posted: Mon May 19, 2008 10:01 pm
first time i've seen it done that way joeblow, not a bad idea at all
i did similar with mine, chopped the front output off, welded it shut to still hold oil. used 2 sierra flanges bolted together to join them, and they were then mounted solid together.
steve got some pics of it on here somewhere
Post Posted: Mon May 19, 2008 10:59 pm
saw the pics. did the same thing bout 14 years ago, problem was too many vibes. i now make em half the size and had new rear output splined flanges made.you only end up moving the stock transfer back about 50- 70mm, unfortunately a little more with a 4 speed auto. this way i can keep em pretty cheap and simple....but oh so tuff too. remember, will do nothing for highway gearing, and better suited to diff gears than rockhoppers.
Post Posted: Tue May 20, 2008 2:36 am
ah, so are you from 4play in victoria?
have you got a pic of the complete setup?
Post Posted: Tue May 20, 2008 3:42 am
ummm...yes...formerly 4play.....moved on to bigger things...not patrols or tojos but. try get some pics up soon.
Users browsing this forum: No registered users and 434 guests
