It is currently Wed May 06, 2026 3:57 am
Post Posted: Wed Jul 14, 2010 3:02 am
I'm just about to fork out $450 for a complete steel GV front diff.
Just checking that a '99 GV Steel diff will fit my '97 Vit, Both are 26 spline and I've got the 5.12 R&P ready to go, so I just have to have the 5.12s swapped into the new GV diff ... is that right ??? :?
Virgil the Vitara
SV620 Estate
Post Posted: Wed Jul 14, 2010 3:06 am
yep
Post Posted: Wed Jul 14, 2010 3:08 am
there are 2 types of pinion mounts.... being a 99 it will be the early type that are the same as the SV's
late model
early model
Post Posted: Wed Jul 14, 2010 3:10 am
that looks yuck.
Post Posted: Wed Jul 14, 2010 3:15 am
Good stuff thanks guys ... yeah that does look yuk (ouch)! 8O
Virgil the Vitara
SV620 Estate
that looks yuck.
pure alloy goodness....
Post Posted: Wed Jul 14, 2010 3:17 am
You really have to wonder 'what the f#@k' were Suzuki thinking?
Virgil the Vitara
SV620 Estate
Post Posted: Wed Jul 14, 2010 3:22 am
with coilys and jimnys also..
Post Posted: Wed Jul 14, 2010 6:23 am
It was late 98 suzuki changed the pinion mounts
You can fit the later model diffs but ya have to bash the sump in to make room for the pinion mount
Gus can ya post up the link that ya sent me with the pics of belted in sump
Post Posted: Wed Jul 14, 2010 9:46 am
really... i thought it was after 99.... SORRY
http://auszookers.com/index.php?name=Fo ... 639#128639
Post Posted: Wed Jul 14, 2010 9:53 am
Yeah the one i was gunna buy off Redzook was from a late 98 model and had the different mount and Stueys is from an early 98 model :wink:
Post Posted: Wed Jul 14, 2010 10:01 am
Ended up keeping it and gonna do some sump bashing :twisted:
waste not, want not...
The LWB From 1993. Poetry in motion :P
Post Posted: Wed Jul 14, 2010 10:04 am
Wasn't Royce gunna get it off ya?????
Should of sold it to that fella from the NT,didn't he offer ya $600 for it 8O
Post Posted: Wed Jul 14, 2010 10:13 am
I've paid my deposit now so I guess I will see when I pick it up next week (after pay day) :cry: , worst case scenario I will knock the sump in a bit, or maybe fit diff drop brackets!
Virgil the Vitara
SV620 Estate
Post Posted: Wed Jul 14, 2010 11:24 am
Yes that was a confusing episode, lots of um-ing and ah-ing ad non-replied PM's so i thought bugger it, i'll just keep it (probably won't find another for 250 again so perhaps for the best). it's still out of the car awaiting a tax cheque to install a locker before it goes in armsup .
Back on topic, hope it all works for ya mick :)
Post Posted: Wed Jul 14, 2010 11:41 am
Thanks mate, will let you know how it goes :?
I take it the pinion mounts can't be changed either ... :evil:
Do all the mounting holes etc, still line up with the original ones ?
Virgil the Vitara
SV620 Estate
Post Posted: Wed Jul 14, 2010 3:07 pm
Ooooh, tax time... there's a tempting idea I didn't need...
Post Posted: Wed Jul 14, 2010 3:12 pm
the mounts on the outside are the same, the pinion mount is different where it bolts to the pinion carrier but where they pinion mount bolts to the crossmember is the same.... grab all of the pinion mount off the GV.
Post Posted: Thu Jul 15, 2010 7:19 am
Thanks Atari I will do, I will see what it looks like when I get it. I may even grab another sump and cut n shut the corner off it and get it ready prior to fitting the diff it is looks like it's going to foul.
Virgil the Vitara
SV620 Estate
Post Posted: Thu Jul 15, 2010 7:25 am
mine did the sump mod on its own
i had to re drill the holes ine the mounts because of the amount of drop my diff has
i made it ge as far forward as i could
Post Posted: Tue Jul 27, 2010 5:15 am
Just picked up my GV Steelie and that f#@k it's got the same pinion mount as the one I've got in it now, so all should be good :D
Virgil the Vitara
SV620 Estate
Post Posted: Thu Dec 30, 2010 9:56 am
Grave dig will the later model pinion mount foul on the sv620 v6 sump
Post Posted: Thu Dec 30, 2010 10:03 am
i "think" tombutt is running the later pinion mount
Post Posted: Thu Dec 30, 2010 10:13 am
Ok I'll check his build up thanks
Vehicle: 2004 SQ625 GV
Post Posted: Fri Dec 31, 2010 5:53 am
My Gv is a 99 and has the same pinion mount as the sv, as atari said.
The alloy diffs are fine at doing what they were designed for. Suzuki didn't plan on fitting 31's, 5.12's and lockers when they designed them
Post Posted: Fri Dec 31, 2010 6:00 am
I broke mine on stock highway terrains
I have confirmed with tombutt that the later gv mounts clear the h20 sump easily so that makes it easier for people with the sv620 models
Users browsing this forum: No registered users and 64 guests
