It is currently Thu Jul 30, 2026 9:54 pm
Post Posted: Tue Jan 04, 2011 12:48 pm
Ummm ok well my body lift kit has arrived thanks to justcruising. And I was looking for the guide to do the lift itself.
http://www.outerlimits4x4.com/viewtopic.php?t=93393
But I was having a read through. And are ALL the steps that he does crucial?
Such as removing the boot from around the g/stick and t/stick?
And what are the main things I need to look at when lifting it up? Apart from the brake lines? :lol:
My build: Click WWW
Post Posted: Tue Jan 04, 2011 12:59 pm
when lifting it up look 4 fuel filler undo that and as u said brake lines and jack it up and put wood blocks or something between the chassis and body so it doe's not fall onto ur fingers when u are putting the lift blocks under
if u drive a loud toyota ute u drink rum
Post Posted: Tue Jan 04, 2011 1:03 pm
I will be using my misses fathers big Mechanic jack :D
My build: Click WWW
Post Posted: Tue Jan 04, 2011 5:48 pm
which has given you a false sense of security so means its even more important to make sure you use stands and chocks!
Post Posted: Tue Jan 04, 2011 6:09 pm
exactly never work on something supported just by a jack
Vehicle: SV420 SE416SWB SE416LWB SIERRA
Post Posted: Tue Jan 04, 2011 6:51 pm
are you saying never trust a jccck?
Post Posted: Tue Jan 04, 2011 7:39 pm
Greg's kits come with full instructions?
Post Posted: Tue Jan 04, 2011 11:01 pm
Yep, if you follow all the instructions supplied you shouldn't have trouble
Post Posted: Wed Jan 05, 2011 1:37 am
Hahaha Whoops :s
Didn't open the Aus post Packet properly. Haha cheers
My build: Click WWW
Post Posted: Wed Jan 05, 2011 2:01 am
sickzuk1 wrote:
Hahaha Whoops :s
Bwhahahahahahah :roll: :wink:
Users browsing this forum: No registered users and 318 guests
