It is currently Tue Jul 28, 2026 10:42 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Sun Jan 02, 2011 11:34 am
Yeah if I can not find a diagram I will just trace it back into the wiring loom, it is just easier with the diagram.
There must be different models of the ECU. I have a partial diagram that PJ.zook sent a while ago that appears to be correct for my ECU. It is attached.
There is also the model information of my ECU and a photo of the PCB.
Vehicle: Zookless
Post Posted: Sun Jan 02, 2011 12:05 pm
I'll agree with Mr. Fat.
According to my diagram, A11 = Engine start switch.
Vehicle: 4wd
Post Posted: Sun Jan 02, 2011 9:04 pm
Just beaware that there are a few different models of computers running this motor, and the wiring codes are very different.
Watch out or you'll get sued.
Vehicle: Zookless
Post Posted: Sun Jan 02, 2011 9:40 pm
Zachius, my ECU has all the same numbers as your does. I used PJ's partial diagram and it all worked.
Yes, A11 is VCC. I was looking at a different page when I posted last time.
I've attached the complete pin-out for you :)
Vehicle: 4wd
Post Posted: Sun Jan 02, 2011 10:04 pm
Can anyone tell me where the powersteer idle up connects up in the loom?
Post Posted: Sun Jan 02, 2011 10:08 pm
You won't/shouldn't need it. Mine ran perfect without the load signal. (Vit system)
Vehicle: 4wd
Post Posted: Sun Jan 02, 2011 10:10 pm
Cool. I didn't think I would need it, but was going to have it just in case.
Post Posted: Sun Jan 02, 2011 10:12 pm
Agreed, but in the one you put up, C16 pss
Post Posted: Sun Jan 02, 2011 10:17 pm
It should be the Powersteering pressure switch. C16. From my hand written notes from years ago! Its a Green with White stripe off the ecu.
If you need the colours for any other motor running wiring, i have them all written down here. 2000 coilpack motor. Unsure ECU Number.
Post Posted: Sun Jan 02, 2011 10:26 pm
Thanks CairnsZook. That looks like what I need.
Vehicle: 4wd
Post Posted: Mon Jan 03, 2011 3:39 am
Thanks guys.
I'm stuck on 'EL+' it's a Pink/Black wire from A16
It runs to a diode in the J/B then comes out as Red/Yellow and Brown/White.
Anyone know where the diode is? I can locate it. Is J/B a junction box?
Post Posted: Mon Jan 03, 2011 3:41 am
I ran no load signals into the ecu.
Vehicle: 4wd
Post Posted: Mon Jan 03, 2011 3:43 am
Headlight idle up and demister idle up :?
Post Posted: Mon Jan 03, 2011 3:45 am
The G13b/a is a POS!, You hear the thing idle up whether you turn the fan on or put your lights on. The G16b doesnt need it. The Bal alternator can handle it. No Drama's.
Vehicle: 4wd
Post Posted: Mon Jan 03, 2011 3:53 am
Thanks Tim!
Vehicle: 4wd
Post Posted: Sun Jan 09, 2011 4:21 am
Can someone tell me why no one uses the stock sierra tacho? Can't it be wired up? or do you have to use the baleno tacho?
ta
Vehicle: Zookless
Post Posted: Sun Jan 09, 2011 4:44 am
PJ's diagram says the Sierra tacho will not work. I didn't even try.
I have no idea why it doesn't work, maybe Tim knows.
It wasn't that hard to install the Baleno Tacho, just a little fiddly.
Post Posted: Sun Jan 09, 2011 7:34 am
I used Bal tacho and faces for both speedo and tacho, vit vss cable speedo mechanics.
Vehicle: 4wd
Post Posted: Sun Jan 09, 2011 8:14 am
Do you know why the standard sierra tach won't work?
Post Posted: Sun Jan 09, 2011 8:18 am
it's not something to do with the twin coil pack motor?
Post Posted: Sun Jan 09, 2011 8:23 am
Correct. There is a mod you can do to the sierra tacho, but cant remember, extra resistor something.
Vehicle: sj80
Post Posted: Sat May 23, 2015 9:04 am
Hey guys, currently about to start my own 1.6 conversion.
The only thing I'm worried about is the tacho. Is it possible to keep the stock coily tachometer face? Even better, to keep the entire stock tachometer in place?
Post Posted: Sat May 23, 2015 6:22 pm
I didn't do my own conversion but I have the stock tacho , if I remember rightly it just takes one resistor changed or added .
The guy that did mine found out how from suzi store in Perth.
You could shoot them an email.
Post Posted: Sun May 24, 2015 3:07 am
I looked into this a few years back but I can't find the details. If someone has a tacho to hand then if they can post up the number on the chip I should be able to find something.
Vehicle: sj80
Post Posted: Sun May 24, 2015 6:30 pm
and i'm back, with photos!
So, here they are (Baleno Coil Pack on top, Vit 16v below)
As you can see, Bal is smaller.
The flipside:
And the flipside-flipped:
Plot twist, they're identical!
The only difference going on that I could see, is the Bal tacho, has an "E" printed on it
Post Posted: Sun May 24, 2015 8:54 pm
Yes, the circuit should be the same but the component values may be different.
Post Posted: Mon May 25, 2015 12:20 pm
My first zook I used the Baleno Tacho circuit grafted into the Sierra Cluster, with Baleno gauge/face and cut down Baleno shroud to suit gauge. I also ran Baleno Speedo Gauge.
My new one has a Sierra Gauge but Baleno circuit. Baleno real RPM is remarked by a tiny line with a texta..Its close enough though. When it idles it purrs, When you hit max revs it bounces of the rev limiter from the ecu. So you don't really need the Tacho.
Vehicle: sj80
Post Posted: Tue May 26, 2015 7:06 am
Have i posted the corrected code?
Ate you able to find anything?
Post Posted: Tue May 26, 2015 5:49 pm
What I need is the number that is on the integrated circuit.
Vehicle: sj80
Post Posted: Sat Sep 26, 2015 6:28 pm
My 1.6 conv. is 99% ready, simply need to sort out tachometer.
Here are the ICs: (Integrated Circuits)
Baleno:
D 056956-0240
9927K
AUS Carburetor '97 Coily:
D SE258
7S31C
JDM EFI Coily:
ND SE258
1R25B
Haven't managed to find a way to get the tachometer working at all.
Users browsing this forum: Google [Bot], Google Adsense [Bot], whoopie79 and 331 guests
