It is currently Thu Nov 05, 2026 12:04 am
Post Posted: Thu Feb 24, 2011 7:11 pm
If it has a speedo cable is it the one I want to bolt into my 95 Sierra for a reduction? Cheers
Post Posted: Thu Feb 24, 2011 7:23 pm
All versions of Sierra (and LJ!) transfer cases have the speedo cable coming off the back of the case. The type of 1.0 t/case you want for reduction AND to be able to swap flanges to fit a W/T has a light switch just in front of the shift lever. You can see it easily when the case is sitting on the ground, but you can also feel for it if it is still in the vehicle.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Thu Feb 24, 2011 9:45 pm
If you get the 1L transfer case with no light you need to change the flanges on the ends of the drive shafts using half half unis, not the transfer case, and you do need to change the speedo cable too.
The one on the left is a 1.3NT with 6.5s and the one on the right is the no light 1L.
Post Posted: Thu Feb 24, 2011 11:15 pm
Yeah righto. This one looks to have something in front of the shifter. So me thinks it's the right one.
Are the one with the light a straight bolt on job with a flange exchange?
Post Posted: Fri Feb 25, 2011 1:21 am
Yep, the ones on the transfer case. You will need a 27mm (i think) socket, a thin center punch to tap out the pinch an a whopping great breaker bar to undo the nuts
Post Posted: Fri Feb 25, 2011 1:32 am
this is the correct 1.0 jobbie.
Post Posted: Fri Feb 25, 2011 1:39 am
yep that looks like the one.
Post Posted: Fri Feb 25, 2011 1:59 am
Anyone got a 1lt with the light they wanna sell ??
Post Posted: Fri Feb 25, 2011 5:59 am
Jungas - it looks like you have about 31" tyres. I'm not sure a shift light case is the best answer. They are worth good money ( about $400 in the trade) because of the lower gearing.... but a set of 6.5 transfer gears is about $600.. and that includes most of a transfer rebuild.
I reckoned I'd want to put gears in the shift light case pretty soon anywaym so spending more money on the 1.0 case would be a waste.
Post Posted: Fri Feb 25, 2011 6:56 am
WHAT TRADE IS THAT!!!!! 8O I don't know any suzuki driver that would pay $400 for a 1 litre transfer case. they're worth $100 - $150 at best.
Post Posted: Fri Feb 25, 2011 7:02 am
Wring a wrecker and ask....
Post Posted: Fri Feb 25, 2011 8:19 am
yep but i'm in Perth :?
Richo
97 Coily 2" susp lift 2" body lift + more
Post Posted: Fri Feb 25, 2011 8:46 am
Both you guys are wrong!
It's somewhere in between! I sold my 1l no light for $200..
:P
Post Posted: Thu Mar 03, 2011 11:17 pm
Bought mine for $50
Post Posted: Fri Mar 04, 2011 12:42 pm
To say they are worth this or that is nonsence, basicly they are worth whatever someone will pay for them.
Post Posted: Fri Mar 04, 2011 12:47 pm
i payed 200 for one on ebay and i have also found one at the dump
Post Posted: Sat Mar 05, 2011 9:33 pm
That is the perfect example shep, so you could say they worth $200 or worth nothing?
Users browsing this forum: No registered users and 239 guests
