It is currently Tue Oct 20, 2026 6:22 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Vehicle: 30s front locker barwork
Post Posted: Mon Mar 31, 2008 11:23 pm
does ditchin the sway bar make it any worse onroad bcoz i hav jst realised that mine hits on the steering damper
Post Posted: Thu Jul 17, 2008 2:19 pm
I've been getting the death wobbles for a little while now too, if I hit an uneven bit of road at anything over about 75-80k's, which is a bit of a bugger if I'm driving along the Westgate highway in afternoon traffic. :oops:
The wheel bearings seem fine so I'm going to see how I go with a new damper. I got quoted $88 for the damper and $35 to fit, sounds reasonable to me...? There also seems to be a bit of play in the steering, so I'll get the steering box checked as well at the same time, since I don't want to stuff it up by doing it myself!
Post Posted: Thu Jul 17, 2008 2:39 pm
that sounds like a good price for the damper, given coilies dont have one from factory it should make a difference
I have also heard trailing arm bushes can do it too, be careful of fitting urethane ones as things might break
Post Posted: Thu Jul 17, 2008 2:51 pm
Just be aware Clare that a damper will only 'mask' the problem. There is something else that is causing it.
It seems that everyone that has this problem has a different cause, things like uneven tyre wear, king pin bearings/shims, swivel hub seals, trailing arm bushes (as Royce suggested), etc... Might pay to get everything checked for play or wear.
Post Posted: Thu Jul 17, 2008 2:57 pm
Thanks guys! I'm ok with things under the bonnet but a novice when it comes to suspension, so I need all the help I can get :) I'm thinking of taking it to Suziworld since I figure they'd have an idea of what to look for, and I don't know any local mechanics...
Post Posted: Thu Jul 17, 2008 3:02 pm
dont make me type my death wobbles post out AGAIN
in short yes the damper is a cure for the symptom, not the cause BUT sometimes the cause is a combination of tyre size, lift, shock valving or things you just cant change
I had it real bad in mine after fitting power steer, everything was on right so I put it down to my suspension design
Vehicle: 75 Cruiser
Post Posted: Thu Jul 17, 2008 3:04 pm
clare wrote:
I've been getting the death wobbles for a little while now !
ahh the shining has arrived :wink: ......
"a while now" ... far out it's been months and you still haven't fixed it!!
Post Posted: Thu Jul 17, 2008 3:08 pm
Sorry Royce, I wasn't trying to shoot you down there. Just thought her car looked pretty stock so it might be wear and tear rather than modifying? Just my very uneducated guess...
Post Posted: Thu Jul 17, 2008 3:11 pm
hehe I was agreeing with you :)
but suzukis is all about bodging the problem not fixing it :)
Post Posted: Thu Jul 17, 2008 3:13 pm
I know :oops: I'm the only one in the family with a car at the moment, which is making it hard to find even one day to put the bloody thing in :cry: She's overdue for a service too, so I'm doing my damnedest to organise getting the whole lot done in the very near future...
Post Posted: Thu Jul 17, 2008 3:14 pm
Aaahhh... we're all tight arses at heart. My wife says I squeak when I walk... better than being too loose isn't it?
Vehicle: 75 Cruiser
Post Posted: Thu Jul 17, 2008 7:50 pm
clare, have you tested your car out with standard rims and tyres? i see you have the big ATs. Would be good if you could borrow some stocker wheels to try and see if that helps.
Post Posted: Thu Jul 17, 2008 8:27 pm
No, I haven't. The AT's were on when I bought her, and I don't really do anything to them apart from checking the pressure and tread. I don't know anyone in the area with a Zook either, so I can't borrow some stockers easily :(
Users browsing this forum: Google [Bot] and 199 guests
