Print view
Previous topic | Next topic
| Author |
Message |
Cut008
Joined: Fri Oct 08, 2010 6:09 pm Posts: 49 Location: Victoria
 Posted: Sat Mar 26, 2011 11:35 pm |
Tested the Vit up in the Dandenong's yesterday and it failed the hill test.
It's still losing pwr and hopping. If I'm in 1st or 2nd gear it's np but if I'm going up the hill in 4th and doing 60kmph it just shits itself.
Onroad it's fine. I've had it up to 90kmph on flat or slight grades and it still has more to give.
Guess I'm down to the fuel pump or carbie itself. I can't think of anything else causing the issue.
Starting seems mostly fine now. Occasionally I might have to crank the engine over twice to get it going but for the most part it's good.
FullyZooked
Joined: Mon Oct 25, 2010 9:01 am Posts: 1009 Location: Bendigo
 Posted: Mon Mar 28, 2011 5:29 am |
How is the car on fuel? How many km to the tank? When the car stutters does the temp gauge go up?
_________________ Built Suzuki's shall reign Victorious.
Cut008
 Posted: Mon Mar 28, 2011 5:43 am |
Honestly I've never paid attention to the fuel usage. I fill it up once every 2 or 3 weeks. After selling my twin turbo 3000GT anything I drive seems fuel efficient.
I've been paying attention to the temp gauge though and there has been no increase in temperature.
FullyZooked
 Posted: Mon Mar 28, 2011 6:56 am |
Just throwing some scenarios around.
Hopping and hesitation from fuel starvation will usually result in a rise in engine temp. Cause, bad fuel pump-blocked main or secondary in carb.
This is also a symptom of spark breakdown. Cause, bad leads, plugs, rotor button, dizzy cap. Will also cause hard starting.
I would pull the plugs and check colour. If unsure post pics here.
stocker
Joined: Wed Dec 08, 2010 7:16 am Posts: 941 Location: Shidoni!
 Posted: Mon Mar 28, 2011 7:16 am |
I have finally got the solution
G16B MPFI
Works everytime
_________________ Stocker
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Mon Mar 28, 2011 7:59 am |
Like I said last week I rekon it's the FUEL PUMP!!!!
Here's one on ebay.
http://cgi.ebay.com.au/Fuel-Pump-kit-Su ... 35a56cd522
That seller is a member of the Suzuki 4WD club and he's very good to deal with, postage is very quick.
But as they say you can only lead a horse to water, It's up to you if you take our advice.
Cut008
 Posted: Fri Apr 01, 2011 9:10 pm |
New fuel pump installed. Can't test it for a week or so up hills though
Users browsing this forum: No registered users and 43 guests
