It is currently Thu Nov 05, 2026 11:49 am
Vehicle: 4wd
Post Posted: Mon Apr 04, 2011 7:40 am
Does anyone know the part numbers for RHF and LHF Old Man Emu leafs for the Sierra?
Watch out or you'll get sued.
Post Posted: Mon Apr 04, 2011 7:44 am
I don't think they make them specifically for left and right.
When I bought mine the guy said the springs are marked with a '+' '-' or '0' for if they are above below or on spec for the spring rate.
He said they try and give you two different ones so you can put the stronger one in the drivers side
My Rig --> Click WWW
Vehicle: 4wd
Post Posted: Mon Apr 04, 2011 7:49 am
So + would be the firmer/stiffer spring?
Post Posted: Mon Apr 04, 2011 7:59 am
Or slightly more cambered
Lil Foot!
Vehicle: 4wd
Post Posted: Mon Apr 04, 2011 8:02 am
Cool.
Should I remove any leafs before I fit them/
Rears
Fronts
Vehicle: 1985 Holden Drover
Post Posted: Mon Apr 04, 2011 8:05 am
Owww nice, how much did they set you back stockman?
1989 WT Sierra.
Post Posted: Mon Apr 04, 2011 8:06 am
stockman wrote:
Cool.
If they are medium duty and your putting them in your hardtop they no, they work perfect the way the are!!
Lil Foot!
Vehicle: 4wd
Post Posted: Mon Apr 04, 2011 8:09 am
I believe there are old two dutys? Standard and Softs?
These are suppose to be softs.
Springs are $81each for fronts and $111 each for rears.
Post Posted: Mon Apr 04, 2011 8:12 am
Ones i saw listed were mediums and HD's, but yea if they arn't HD's just throw they in as there are. I suggest using the OME bushes as well, otherwise you may push out the pressed sleeves in the big eyes of teh springs
Lil Foot!
Post Posted: Mon Apr 04, 2011 8:27 am
http://auszookers.com/index.php?name=Fo ... ic&t=18954
Bottom of the page is a list
Users browsing this forum: dphogan and 39 guests
