It is currently Thu Nov 05, 2026 2:56 pm
Post Posted: Mon Apr 04, 2011 8:14 am
Always wondered what the differences were between the two, stock from factory. Does anybody know?
Lil Foot!
Post Posted: Mon Apr 04, 2011 8:16 am
Edit: softtop and tin top both have a gvm of 1340kg but you probs knew that already
Vehicle: 4wd
Post Posted: Mon Apr 04, 2011 8:17 am
I thought my soft top way 1050.
Watch out or you'll get sued.
Post Posted: Mon Apr 04, 2011 8:18 am
just lik cutting a tin top down to make it a softie won't work because the soft tops more additional braces to keep em ridged....
Post Posted: Mon Apr 04, 2011 8:34 am
My 1990 sierra had a GVM of 950kg. or thats what was on the rego sticker
Post Posted: Mon Apr 04, 2011 8:40 am
My 1990 Sierra has 1340kg :?
Post Posted: Mon Apr 04, 2011 8:44 am
i had mine on a weighbridge after modifying it and with water pooled in the softtop it weighed 1040kg... i'd say stock would be 950-980.
Post Posted: Mon Apr 04, 2011 8:54 am
So if they ain't 1340 what's is this gvm crap they put on the badges
Is gvm the weight of the vehicle when there's 4 ppl in the car
Post Posted: Mon Apr 04, 2011 8:57 am
Sure it wasn't a Tare weight of 950kg? Otherwise, you wouldn't have been able to put a driver in it, let alone anything else!
I want my old sig back :(
Post Posted: Mon Apr 04, 2011 9:14 am
yeh my bad
Post Posted: Mon Apr 04, 2011 9:18 am
GVM - Gross Vehicle Mass the most the vehicle is allowed to weigh loaded
Tare should be the weight of the vehicle unloaded
lost in suzuki space
Post Posted: Mon Apr 04, 2011 9:49 am
all the weight is in the body
Post Posted: Mon Apr 04, 2011 9:54 am
mine had been stickered on the side with GVM and Tare when i bought it..
880kg tare
1340kg GVM
dont now how true this was ...
Post Posted: Mon Apr 04, 2011 10:06 am
880kg tare
1340kg GVM
Tare weights are often quoted as "dry weight" so add a tank of fuel, oils, coolant etc and you get closer to the true unladen weight of the vehicle...
Post Posted: Mon Apr 04, 2011 10:13 am
You guys are doing it wrong. :lol:
I've cut the roof off a hardtop before and it would be lucky to weigh 30kg incl. half the c-pillars.
Post Posted: Mon Apr 04, 2011 10:56 am
Ok so 30kg roof + rear glass + side glass + rear door?
Reason why im bringing this up is that the aftermarket springs and loading seem to change weather you have a steel bar, winch etc etc, but no differences between soft and hardtop zuk. Since owning now both hard and soft tops I have noticed quite a significant difference to how the springs sit and ride between the two.
Lil Foot!
Post Posted: Mon Apr 04, 2011 1:59 pm
I don't have Sierra weights, but according to my LJ80 FSM:
its 740kg vs 785kg for LJ80-II Stockman; and 705kg vs 750kg for LJ80-I. So 45kg difference, I can't imagine an SJ having a very different difference.
Clearance Hole Technology :P
Users browsing this forum: No registered users and 43 guests
