It is currently Sat Aug 01, 2026 6:44 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Post Posted: Sun Apr 10, 2011 10:18 am
Ok so finally bought me a vitara :d couldn't be happier.
Took it wheeling and then the problems started.
Drove up a hill and had a horrible burning smell. Rode the clutch a tiny bit but nothing chronic. Then went to change gears an wouldn't go in.
So figured I burnt the clutch went to adjust it and it was almost at it's limit.
Worked well.... Next hill the clutch burnt again. Same problem.
Was at it's limit.... Adjusted it a tiny bit and worked fine. Got it home and went to duck to the shops and gears wouldn't select again.
I had a good look and seemed like the cable was stretched. Put a temp spacer in the cable now have plenty of adjustment :s
Clutch engages when pedle is halfway out (when I got it it engaged as soon as it was off the floor)
My questions are:
Why did the clutch burn so easily?
Why did I have to adjust it so much?
Now that I have a spacer in it and it's working. Is that a good sign that it's not the clutch and just needs a cable?
Also, my starter keeps spinning even after the cars started? Is there a way to fix that or just buy a new one?
Post Posted: Sun Apr 10, 2011 10:22 am
Also, clutch is very heavy. Kind of hurts pressing it to the floor haha
Post Posted: Sun Apr 10, 2011 10:27 am
Seems as though you bought a good one hey :? Sticky solenoid perhaps on the starter, clutch...how old is it, how many km's has it done?
Post Posted: Sun Apr 10, 2011 10:28 am
Firstly, pic's of car!!!!
& sound's like the cable is frucked, or the pressure plate is collapsing..
Post Posted: Sun Apr 10, 2011 10:35 am
I'm guessing Clutch cable. Working well now. But then again I haven't done any offroad since the spacer.
One thing I did notice. The arm that the cable connects to. The shaft that goes into the gearbox wobbles when you press the peddle. Like the bush is flogged out.
Thrush bearing is a bit noisy.... Wasn't when I bought it though.
Guess I'll try the cable first. Jus don't know why it burnt so easily.
Pics soon :) on the camera.
Vehicle: 4wd
Post Posted: Sun Apr 10, 2011 10:42 am
Pics!
Watch out or you'll get sued.
Post Posted: Sun Apr 10, 2011 10:55 am
I'll upload some tomorrow
Post Posted: Sun Apr 10, 2011 9:17 pm
I'd say pressure plate is on its way out...
Post Posted: Mon Apr 11, 2011 5:37 am
What makes you think that?
Clutch is quite heavy? I've heard heavy duty clutches stretch cables and snap them easily... Could it possibly just be the cable?
Post Posted: Mon Apr 11, 2011 8:04 am
Worked fine this arvo. Then all of sudden went to change down gears and it wouldn't go in !!!!
Didn't burn the clutch or anything.
There is no weight on the pedle. Hope it's just a snapped cable but something tells me it's more.
Where's the cheapest place to buy a clutch? And who wants to help me put it in ??? :d
Post Posted: Mon Apr 11, 2011 8:09 am
When???
Get a genuine rear main to, don't bother replacing the seal unless is a genuine one..
Post Posted: Tue Apr 12, 2011 5:48 am
Well had a look. The cable isn't snapped. However the arm is a fai way back. (clutch doesn't even feel like it's engaging.
Clutch arm is all the way back. When I adjust it it moves in a fair way.
To me it seems either the cable is stretching like crazy or the actual arm is slipping on the shaft??
Post Posted: Tue Apr 12, 2011 5:52 am
sounds like the arm is slipping on the spline of the shaft...
If you don't get stuck you aint tryin' hard enough
Post Posted: Tue Apr 12, 2011 5:56 am
pull the cable out and have a good look, especially where it bends around the bottom radiator hose
Post Posted: Tue Apr 12, 2011 6:02 am
Can anyone see what I see??
Post Posted: Tue Apr 12, 2011 6:13 am
yeah its fucked
Post Posted: Tue Apr 12, 2011 6:19 am
Post Posted: Tue Apr 12, 2011 6:34 am
So could this be my problem?
Suzuki want $120 :/
How much from Suzisport or the likes?
Post Posted: Tue Apr 12, 2011 6:39 am
Is this the one ?
http://cgi.ebay.com.au/Suzuki-Vitara-1- ... 500wt_1156
Post Posted: Tue Apr 12, 2011 6:43 am
its a late 95, early 96 going by the dash?
they are a different cable to the ebay one, you have a rubber bung on the block mount
the genuine ones are crap, suzisport ones are crap, I have a sierra one from suzistore, has lasted the longest of them all but you need to make a new mount on the block
If it has a heavy duty clutch buy a few so you can change it monthly :) but I think in your case its been installed wrong and thats caused the problem
Post Posted: Tue Apr 12, 2011 6:53 am
Yeah before I bought the car aMechanic had re-greased the cable so they must have installed it wrong.
So when they are kinked like so, would that stretch the cable like it has been.
Kind of doesn't explain why it burnt so easily? Does it?
The inner cable isn't kinked. Just got a curve from the outer....
Post Posted: Tue Apr 12, 2011 7:02 am
lol, you cant regrease them they dont come apart
the inner doesnt stretch, the outer collapses which has the same effect
what happens is the heat from teh bottom hose softens it and the pressure from holding in teh clutch stretches it till it splits, this is all made worse from 4wding cause its low sped lots of clutch use so it doesnt get to cool
mine goes between the hose and the alt, with some hose around it to try and stop some heat
Post Posted: Tue Apr 12, 2011 7:22 am
Thanks Royce!
Glad you told me where to look. Never looked there haha checked everywhere else.
Has this happened before?
Post Posted: Tue Apr 12, 2011 7:28 am
yeah I went through a few before figuring it all out, including replacing the clutch cause I thought it just failed when it was a buggered cable
Post Posted: Tue Apr 12, 2011 7:30 am
Well I'll source a new one and hopefully it's just a cable....
Stay tuned!
Post Posted: Wed Apr 13, 2011 6:23 am
Well about 10 minutes work and $77 later.
My dear old Tara was back purring like she should be...I hope this had fixed it. I think I need to put a lock nut on the adjuster. Pedal position is different now to when I took her out.
Post Posted: Wed Apr 13, 2011 6:28 am
new cable stretches a bit usually once its had some tension on it
Post Posted: Wed Apr 13, 2011 6:31 am
Thought as much.
I took it out for about 45 minutes and I didn't need to adjust it once. Plus there is a fair bit of thread left on the adjuster (about half way)....
I could kiss you Royce :d
Post Posted: Wed Apr 13, 2011 6:40 am
8O I'm not homophobic but I'd rather not see this!! 8O
Post Posted: Wed Apr 13, 2011 6:43 am
Because you wanna be in on it? :D my lips are big enough for the two of you!
Users browsing this forum: Google [Bot] and 75 guests
