It is currently Mon Nov 02, 2026 7:37 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
Post Posted: Mon Aug 29, 2011 1:36 pm
alexvitara wrote:
the curclip on the axle will be holding the hub on. if you take the other six bolts on the free wheeling hub off you can get to this curclip and remove it, thus removing the hub.
Pic will help. Remove the cover of the free wheeling hub with the 6 10mm(M6) bolts. There is a circlip (No 35 in the diag) clipped in the end of the axle shaft. This will then allow the body of the FWH to come off the hub. To remove the hub to drill out the broken bolts, you will have to undo the wheel bearing nuts (No 12 in the diag, there's 2), these are a 50mm nut. You should use a 50mm socket to undo them, but some ****s use a cold chisel and hammer to undo them and then try to get an accurate torque doing them up the same way.
Post Posted: Mon Aug 29, 2011 2:01 pm
alexvitara wrote:
Yeah i can help you out tomorrow arvo.
:goodjob: Armsup Armsup Armsup Armsup Armsup Armsup :peaceout:
Vehicle: Daisy
Post Posted: Mon Aug 29, 2011 7:49 pm
I have a 50mm socket here I've borrowed to do my wheel bearings if you need to use it let me know.
Post Posted: Mon Aug 29, 2011 8:49 pm
Thanx for that pic 303zook. Champion!
Yeah Alex head over after work i have a garage and driveway, we'll work something out. Just text us when your driving back from brissie...
I might need that 50mm socket Teracis... ill ring ya if i get stuck!!
Cheers boyz.
The Green Machine!
Post Posted: Tue Aug 30, 2011 9:21 am
couldnt do it this arvo because i had to go pick up a little sister for kermit but i'm going around tomorrow arvo.
that 50mm socket would be handy, what you doing tomorrow arvo tim?
i could pick it up on the way through if you going to be home?
Post Posted: Tue Aug 30, 2011 9:53 am
Do u have a t-bar wheel brace Alex? u know the ones with different size heads? if so bring it round can ya... i swear the nuts on my wheels are different sizes... lol.
The Green Machine!
Post Posted: Tue Aug 30, 2011 10:05 am
no i dont but i've got sockets, a breaker bar and a pole. we can make it work.
or you can shoot down to supercheap and get one. i think there like $10 or something. i have 2 different sized nuts on my wheels too :lol:
Post Posted: Tue Aug 30, 2011 11:16 am
yeah the sockets and breaker bar will work!! sweet!
The Green Machine!
Post Posted: Tue Aug 30, 2011 11:18 am
When i go to the nut n bolt shop to buy new bolts for my locking hubs im gonna pick up some wheel nuts (all one size) then ill get a wheel tool for that size...
The Green Machine!
Post Posted: Tue Aug 30, 2011 11:22 am
actually someone might be able to tell me what size thread the wheel studs are?
The Green Machine!
Post Posted: Tue Aug 30, 2011 11:24 am
M12 x1.25 :wink:
Post Posted: Wed Aug 31, 2011 12:44 am
Champion!!!!!
The Green Machine!
Post Posted: Thu Sep 01, 2011 8:50 pm
Ok, so once i took everything apart and cleaned it all up i became very confused with the reassembly.... for all those in the same position as me i found this youtube vid extremely valuable!!!!
http://www.youtube.com/watch?v=UsBPl2cQlC4
The Green Machine!
Post Posted: Thu Sep 01, 2011 9:04 pm
And this ones even better!!
http://www.youtube.com/watch?v=dxSBcAyt2WA
The Green Machine!
Post Posted: Sun Sep 04, 2011 8:18 am
all sorted now mate?
Post Posted: Thu Nov 07, 2013 8:30 pm
I finaly broke some, been carrying spares for many years.
Mine were stuck too hard for a trail fix.
Going to look into 60 series replacements.
Mine are possibly over 20 years old on the car, and even older spares.
Post Posted: Sun Nov 10, 2013 2:58 pm
Whoever said it was an easy track side repair, go jump :)
After a few hours of hammers, screwdrivers and swear words, only got 4 out.
Attempts to get out last 2 just knackered up the threads.
So now to change the hub.
Waiting for a new bearing in the post now.
(And a stater motor and new 60 series stud kit)
Bearing in the spare hub is putting up a fight, but I'll win.
It's too grindy for even me to use.
Post Posted: Sun Nov 10, 2013 3:26 pm
I bet someone loctited them in.
Never ever use loctite on hub bolts.
Post Posted: Sun Nov 10, 2013 3:43 pm
No loc tite was ever used by me, tho there was evidence of previous use.
Plenty of rust, and a bit of stray gasket goo.
Oh well, a new bearing is wise anyway, as I drove with no hub on through much dust and mud.
Think I may put some anti seize on the new ones, better for track side fixes.
Post Posted: Sun Nov 10, 2013 6:12 pm
That's a great idea.
Users browsing this forum: Google Adsense [Bot] and 409 guests
