It is currently Mon Aug 03, 2026 9:00 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Post Posted: Sun Sep 04, 2011 2:02 am
im sure this has been answered many times but im too lazy to search for the thread sooooo whats the largest tire size i can put on my 97 sierra without changing gear ratio for the stock engine,i have heard 31s wont matter but any bigger is a problem yes/no?
Post Posted: Sun Sep 04, 2011 2:04 am
i run 30's and its alright until u hit highway.. 31's would be abit worse..
If in doubt power out!
Post Posted: Sun Sep 04, 2011 2:12 am
215's
Post Posted: Sun Sep 04, 2011 2:34 am
i did a search & it said 37's are fine with stock gearing. :wink:
Vehicle: nt sierra
Post Posted: Sun Sep 04, 2011 2:42 am
215/75/r15 would be about the biggest.
do not run 31's with out fixing the gearing
Post Posted: Sun Sep 04, 2011 2:56 am
I don't understand what all the fuss is about. I just put 31's on my stocker and it drives fine on the road. Offroad, it's still fine for mud and slippery stuff, but doesn't crawl as well as it used to. Overall, it is just fine without any gearing alterations. Will be getting gears when I can afford it though, probably in another 10 years at this rate :roll:
Post Posted: Sun Sep 04, 2011 3:39 am
i had 235/75's on mine, was great but didn't use 5th and low range suffered a bit.
Post Posted: Sun Sep 04, 2011 3:42 am
@atari, yes stock H1 gearing will work. I have put magnets on my fuel line and a hyclone, it puts out about 35% more power.
Post Posted: Sun Sep 04, 2011 4:03 am
So you expect everyone to repeat the same info that's already been discussed a billion times over just cos you're too lazy to search??
Stick 35's on with ya stock suspension and gearing!! That'll help me cos I've got shares in all the major clutch suppliers
Post Posted: Sun Sep 04, 2011 4:19 am
I have 31s on stock gears, works fine, 100kph in 4th if your on flat road, otherwise it's 80/90, hills kill it really have to get a run up and work the car hard to keep anywhere near traffic speed but not undrivable, I never had a problem off road, couple of steep hills had it strugleing but got up, I don't do alot of slow steep rock ledges that would be difficult. All in all you'll be just fine previding you have correct lift, don't mind a top speed of 90kph and can use a little common sence offroad, maybe use the search function next time this is something covered a million and one times haha
Hope this helps
Post Posted: Sun Sep 04, 2011 4:29 am
31's with stock gearing is not fine. Don't lie to him.
31's with a 1ltr transfer is bearable to drive around town, but in the bush it's not awesome.
225's are the biggest I would go with stock gearing.
235's and up I'd be looking at a gearing fix.
Post Posted: Sun Sep 04, 2011 4:50 am
I am not lieing, I have 31s and stock gearing and my car goes just fine, I have never had a problem on or off road, as explained it's not ideal but perfectly drivable there are so many fear mongering on this forum sometimes. But saying I'm lieing, and any SA auszookers can back up my statement that it goes just fine. Not ideal ( as I thaught I maid clear) but wold just fine
Vehicle: LJ20 LJ50
Post Posted: Sun Sep 04, 2011 5:10 am
I sure I have answered many times and am too lazy to do it again.......
Camels have nice toes
Post Posted: Sun Sep 04, 2011 5:46 am
It does GO yes. You can DRIVE it yes. But its fucked.
The clutch slips when trying to drive up decent sized things.
The fuel economy is crap.
It has a very slow pick up trying to drive around town and you end up in second trying to get up a hill.
5th is not useable unless you have a decent downhill stretch.
It's shit. 1ltr transfer at the LEAST, even then its shit.
Post Posted: Sun Sep 04, 2011 6:08 am
You got that right mate, so true! :)
Post Posted: Sun Sep 04, 2011 6:38 am
My 1.3 with stock gears and 31" claws went fine on 31s, not much could touch me off road, on road, 90k by the speedo was it, maybe 95k, but tht is 13% overdriven, so in theory I was doing around 110k, i could even tow a trailer full of wood in top gear.
I swapped over to 4.11 diff instead of 3.9s and a 1l Tcase, tis better, but stock an 31s is very do-able.
Post Posted: Sun Sep 04, 2011 7:00 am
doing anything remotely technical with larger tyres & no gearing will leave you skull fucking your clutch to go anywhere without stalling.
Post Posted: Sun Sep 04, 2011 7:44 am
Thats the nicer way of putting it :lol:
Post Posted: Sun Sep 04, 2011 8:00 am
i like skull fucking my clutch......shows it whos boss lol
Post Posted: Sun Sep 04, 2011 8:07 am
Technology and me live on different planets.
Post Posted: Sun Sep 04, 2011 9:34 am
We already know that one :mrgreen: :peaceout:
Lil Foot!
Post Posted: Sun Sep 04, 2011 9:39 am
sounds like a fair bit of trouble for 31s, maybe 30 inch would be a better compromise i just need more clearance, my diff has copped a beating recently.
cheers for the replies
Post Posted: Sun Sep 04, 2011 9:41 am
Your definition of 'fine' must be different over there. Stock WT 1.3's with 31's are puss. Forget using 5th gear and cruising at 100 comfortably with some sort of fuel economy or doing any sort of controlled hill starts.
Lil Foot!
Post Posted: Sun Sep 04, 2011 9:54 am
I think that is the point everyone is making 'fine' is a relative term :wink:
Not much point going to 30's instead of 31's you will still need to address gearing eventually. Personally I would go 31's, learn to live with it and aim for gears in under 12 months. I had 215r15's which are the same size as 235's and I felt it was fine, 31's were liveable, but I did get gearing with in 6 months to make life alot easier both on and off road.
Post Posted: Sun Sep 04, 2011 10:42 am
Red89 wrote:
I had 215r15's which are the same size as 235's.
Post Posted: Sun Sep 04, 2011 11:03 am
pompoms
Post Posted: Sun Sep 04, 2011 11:27 am
I lied they are 28, 235's are 29 my mistake.
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Sun Sep 04, 2011 11:46 am
I run 235/75/15's on my coily with stock gearing and it goes great.. Easily sits on 120kph in 5th gear.. Doesn't speed up quite as quick as it did when i ran 215's but it still goes fine (if your not drag racing every random P plater off at the lights you won't notice it ;) Even with 4 people and lugguage for 2 nights it still goes fine on the highway up the sunshine coast etc..
Subi + Suzi = Best of both worlds!
Post Posted: Sun Sep 04, 2011 12:01 pm
120 easily!!! i dont think i have taken mine over 100 , it has got BFG muddies not sure on the exact size il have to check that out but i definitely need more ground clearance
Vehicle: '96 LWB trayback
Post Posted: Sun Sep 04, 2011 12:17 pm
I'm yet to see a sierra that will do 120 easily on larger tyres with a stock engine. And I've driven more than my fair share.
My swb would do 100kms comfortably in 5th gear even around hills.
When I went to 235/75 15's I gave up on using 5th, even on flat ground.
Hills I used to climb in 5th I now needed to go to 3rd, and would normally be forced to slow to around 70km/hour.
Gearing IS required onroad for this size or larger.
Offroad, lowrange is crippled. Your clutch will cop a hiding on anything other than a basic forest trail.
Users browsing this forum: No registered users and 76 guests
