It is currently Mon Oct 19, 2026 12:00 pm
Post Posted: Tue Dec 23, 2008 2:12 am
My sierra 1 liter motor is not reving up in low range or high
I cleaned the carby out but nothing
or it could be the bigger wt diffs to.
Post Posted: Tue Dec 23, 2008 2:19 am
nar stop the fat chick that cant jump from sitting on it 8O
Post Posted: Tue Dec 23, 2008 2:24 am
those stands that dropped under your car.. .are they still under there?
actually... if you ask damo..... he may think you have run over a matress
Web wheeler extroadinaire
Post Posted: Tue Dec 23, 2008 2:33 am
could be your valve caps?? Have you rotated them lately?? hehe just stirrin.. ummm, check your points.. they are the best place to start :)
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Tue Dec 23, 2008 2:37 am
or your headlight fluid.. :lol:
What happened Noddy?? Short spark in some brainwaves? wtf?
Post Posted: Tue Dec 23, 2008 3:27 am
definately from the WT diffs. is it a recent mod? has it ran since putting them in? i'd be changing back to the NT diffs to see if the problem goes away before looking at anything else.
when you done the diff swap you may have put the front diff in the rear and the rear in front (not to be confused with a RUF which is springs), I have heard of this mistake causing similar problems before.
hope it helps,
Mark.
Post Posted: Tue Dec 23, 2008 3:57 am
hope it helps,
Mark.
that might be it
hello
Post Posted: Tue Dec 23, 2008 4:05 am
push the right pedal down. sorry had to say it
lesspostingmorewheeling
Post Posted: Tue Dec 23, 2008 4:28 am
make sure you turn the key first :wink:
Vehicle: LJ20 LJ50
Post Posted: Thu Dec 25, 2008 9:00 am
Hook the accelerator cable back up.
OR when you beat the wheel wells out you bashed the floor up so much the accelerator can't move any more. ( done this before)
Maybe some more info as to what it is doing exactly _noddy. Then we can offer random advice which may isolate the problem for you.
Camels have nice toes
Users browsing this forum: No registered users and 200 guests
