2stroker wrote:
1 litre clip will bolt on, but 1 litre bonnet may be too low profile.
Coily clip will bolt on, but coily bonnet wont because it is too high at the hing end (i.e. the distance from the top of guard to the top of cowl is greater on a coily) you can use a 1300 bonnet, it will fit but diesnot quite line upat the front (i.e. the coily is not straight across the front edge of the bonnet)
And while the 1 litre front clip will work fine with a 1.3 bonnet, the fittings on the inner guards for things like aircleaner, jack and battery differ slightly.
