It is currently Sun Nov 08, 2026 1:14 am
Post Posted: Sat Nov 19, 2011 4:17 am
How did everyone do their accelerator cables? Or what did you use. The stuff I have supplied just doesn't work out. Pj, supplied what he thought was a baleno accelerator but it just fit. Any ideas on what I can use to make this all work.
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Sat Nov 19, 2011 4:35 am
i used the standard cable and modified the sierra accel pedal
greg
Post Posted: Sat Nov 19, 2011 4:44 am
efi Vit cable.... :helloo:
Post Posted: Sat Nov 19, 2011 4:45 am
Even with the baleno throttle being completely different?
Post Posted: Sat Nov 19, 2011 4:49 am
Pic.........
tis in a different spot, but don't think it's that different that it won't fit/work
Post Posted: Sat Nov 19, 2011 4:55 am
I tried changing the bracket round to make it work however it was then too long for the the adjustment nuts.
And the supplied cable
Post Posted: Sat Nov 19, 2011 5:08 am
greg
x2
If anything it was too long, Mine was down the back of the motor, Then up to the TB
Post Posted: Sat Nov 19, 2011 5:26 am
That look's like a vit cable, try as the others have said....
Post Posted: Thu Dec 01, 2011 10:47 pm
Ok back to this.
Can someone measure their Efi vit cable from ball bearing thingy to ball bearing thingy.
The standard cable I have will not fit at all. Even Joel's brand new cable I borrowed from him for a g13ba will not fit.
Post Posted: Thu Dec 01, 2011 11:11 pm
The baleno cable is straight at the throttle body side
Post Posted: Thu Dec 01, 2011 11:34 pm
I used a vit one i think, but shortened the inner using a brake cable end from a push bike shop.
Post Posted: Thu Dec 01, 2011 11:47 pm
I don't have the stock baleno cable. Just the one supplied by pj.zook and one I pinched from Joel. Both identical. I'm not running a body life which probably answers why over all it too short. But it still itsnt long enough from the bracket to the throttle body
Have you got a picture with what you mean tanshi?
Post Posted: Sat Dec 10, 2011 11:08 am
Problem fixed. Probably not 'legal' in a sense but alot better IMO then dodging it with cable ties and what not.
Used go kart cable joiner crimp joiner ma-bobby thingys. Got a pack of 5 for $6 or something. Cut the cables to length with slack spare on each side. Installed it then tightened it proper job when it was how I wanted it. Works a dream.
Tidied it up after so no loose ends.
Doesn't snag on anything and sits in the baleno stock accelerator holder bracket thing.
Post Posted: Sun Dec 11, 2011 5:12 am
That will probably work fine. There is not much tension on throttle cables.
Vehicle: Sj70 tintop
Post Posted: Sun Dec 11, 2011 5:27 am
not sure of legalities, but i doubt it would be a problem??
looks the goods, not like its a dodged break cable.....
Sj70 tintop
Post Posted: Sun Dec 11, 2011 9:39 am
I owe ya a new cable. Used yours in the end as well cause I cut mine too short :lol:
Vehicle: Zookless
Post Posted: Sun Dec 11, 2011 9:40 am
I used the standard Baleno cable. Just had to mod the pedal end slightly to fit.
Post Posted: Sun Dec 11, 2011 9:48 am
I didn't have the stock cable handy. Just had a g13ba one and a corolla 4k one. Made it flash as for $6. New baleno cable was gonna set me back $30 or something.
Post Posted: Sun Dec 11, 2011 9:55 am
I used a jimny cable when I put my jimny motor in, same manifold design.
Post Posted: Sun Dec 11, 2011 9:57 am
How was the pedal?
Um, I can look at my Jimny tomorrow.. :lol:
Post Posted: Sun Dec 11, 2011 9:39 pm
Post Posted: Sun Dec 11, 2011 9:42 pm
Thanks brenno. Good advice :P
Post Posted: Sun Dec 11, 2011 9:47 pm
Just needed a small nut and bolt to squash the end in the pedal,
Post Posted: Mon Dec 12, 2011 7:00 am
Simply because of the title, I'm going to put this here.....
http://www.ptjau.com/images/sierra/bale ... ringv1.pdf
Post Posted: Mon Dec 12, 2011 7:01 am
Oh, thanks to P.J.Zook.... :helloo:
Users browsing this forum: No registered users and 101 guests
