| Author |
Message |
inbits
Joined: Mon Sep 13, 2010 8:30 am Posts: 600 Location: qld
 Posted: Mon Oct 11, 2010 9:34 am |
joeblow wrote: you're auto had a little more fluid than it should have. when you placed some decent load on it the excess oil came out through the breather for the 4 speed just above the bellhousing. get someone who knows electronic autos and knows how to fill them correctly and it will not be an issue again. atf can catch fire so be very carefull. you will find that now the auto has expelled its excess fluid it won't happen again. rear mains on a H20 do not spray oil like that.......auto breathers do.
The only thing is that the atf fluid is red and the leaking oil is browny black colour and its leaking down the bell housing and the back of the engine block and onto the cross member.
Ill definitely take it to an auto specialist as its been making a weird noise when kicking back from o/d (hard to explain.)
heres a pic looking between the bell housing and engine
thanks for the replys so far guys i appreciate it
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Mon Oct 11, 2010 9:40 am |
behind the passenger side rocker cover is a rubber plug containing the line for the positive crankcase ventilation. check to see if that line has come off, but i've never seen one do that. more common is the auto breather to expell fluid.
_________________ builder of custom road legal zooks......and stuff.
inbits
 Posted: Mon Oct 11, 2010 9:48 am |
Funny enough i checked that today i thought it may be blocked and pressurising the crank case pushing the oil out.
I was blown away too see the oil when i had a look it didnt have 1 oil leak at the start of the day. Ill have another look tomorrow afternoon and try get some better pics the oil only started to leak out once it had warmed up and the oil was thinner.
There is no oil up high in the engine bay or on the fire wall and none on top of the bell housing either
gregdixon
Joined: Sun Dec 28, 2008 10:30 pm Posts: 1017 Location: Perth
Vehicle: 2004 SQ625 GV
 Posted: Mon Oct 11, 2010 11:13 am |
I would say rear engine seal. Mine covered everything in oil like that when it went. It started leaking after a short hill climb. Your converter side of the flex plate will be clean but the engine side should be covered in oil.
inbits
 Posted: Mon Oct 11, 2010 9:51 pm |
Yeah I'm convinced it's the rear main now should I buy genuine or is aftermarket just as good
gregdixon
 Posted: Mon Oct 11, 2010 10:17 pm |
I got a genuine seal from Suzistore for $80. Pretty easy to replace.
tombutt
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1917 Location: brisbane
 Posted: Tue Oct 12, 2010 4:44 am |
id go geniune i havnt had much luck with anything after market for a suzuki
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Tue Oct 12, 2010 4:54 am |
tombutt wrote: id go geniune i havnt had much luck with anything after market for a suzuki
x2
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
inbits
 Posted: Tue Oct 12, 2010 5:15 am |
Suzistores price is 90 dollars plus post and Suzi sport springwood said 93 I'll see if I can get trade price through work thanks for the help guys
inbits
 Posted: Tue Oct 12, 2010 7:33 am |
inbits
 Posted: Sun Oct 24, 2010 7:44 am |
I got a start on doing the rear main today.
I got the:
exhaust off
transfer oil drained
auto fluid drained
and drive shafts out
Now for some more questions
Do i need to remove the autos sump because of the dipstick?
while im pulling the tansmission out should i service it? and is this a hard job?
What will an auto service kit be worth ?
is there anything else i should do while i have it apart?
thanks inbits
zookurt
Joined: Tue Dec 27, 2011 8:11 am Posts: 1 Location: QLD
 Posted: Tue Dec 27, 2011 8:21 am |
I have the exact same problem, oil leaks from above the sump and drips down to the exhaust and when that heats up she starts smoking! pretty embarassing when you rock up to a set of lights! MIDAS told me the engine had to be rebuilt so im not sure what the issue is, i hope its the rear main seeing thats cheaper than an engine rebuild!!
How did you go anyway inbits?
Any advise would be appreciated
thanks
