It is currently Thu Aug 06, 2026 4:01 pm
Post Posted: Sun Jan 08, 2012 2:42 am
Trying to decide on good belly height for my lwb. What height (swb or lwb) are your zooks at? Please list mods you have used to acheive your height.
Im thinking around 17in. Wheelbase of 96in
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Sun Jan 08, 2012 2:55 am
im 20" and 110" WB
what size tyre you aiming for?
Post Posted: Sun Jan 08, 2012 3:12 am
only 33s. but want to be able to run 35 if i need to.
Thinking 3in springs, 1in shackes plus tyres should get me close to 17in
Post Posted: Sun Jan 08, 2012 3:14 am
dunno because i don't have a tape measure that works in old fashioned units.
Post Posted: Sun Jan 08, 2012 3:15 am
no reason why your 2" spring, 2" bodylifted sierra cant run 33's right now with a bit of a guard chop and hammering...
you dont want to make the wheelbase too long or your rampover angle is going to suffer bigtime.
mines not here to measure, but on 31s with a roughly 200mm extended wheelbase i certainly wouldnt want to be any longer, i already have issues now and then bellying out.
Post Posted: Sun Jan 08, 2012 3:24 am
I have another lwb im building, seperate car altogether. Its pretty stock now so just wanting to get all my plans worked out before i start.
Post Posted: Sun Jan 08, 2012 3:27 am
My vits at 14.5 " at 98"'wb and it drags it belly all the time
Post Posted: Sun Jan 08, 2012 3:44 am
There is draw backs to any way you build, spoa will get you insantly better ramp over approach and departure, but suffer on side angles. low with chopped guards will get you great side angle but suffer ramp over etc etc....
if i was building a lwb on 33s it would be 50mm spring lift, guard chopped.
Post Posted: Sun Jan 08, 2012 10:04 am
so what exactly are we taking the measurements from?
the chassis or all the crap hanging below it? big difference
Post Posted: Sun Jan 08, 2012 8:07 pm
96" wheel base
22" to bottom of transfer
F#%ING [P] PLATER
 Profile YIM
Post Posted: Sun Jan 08, 2012 11:12 pm
should measure to the chassis rails at a certain point, as some people to transfer lifts or run different boxes etc... so while it might not be 100% accurate cos other shit hangs down, at least its a common spot to measure to.
Post Posted: Mon Jan 09, 2012 12:07 am
But that would be chassis hieght not belly hieght, my understanding is belly hieght means lowest point, whatever that may be on your vehicle. Anyway from memory Im at 22 inches with a flat belly, on 38s and 110 inch WB.
Made in JP. Built in WA.
14.5" and 88" wheelbase.
Measured to the bottom of the chassis because LJ81s are awesome so no crap hangs down past it. :helloo:
Post Posted: Mon Jan 09, 2012 12:40 am
102WB
35's
16" to the lowest point on the chassis (other than the front spring hangers)
Mods to achieve the height? Flogged out OME front springs, slightly modified rear end :D
On my LWB 1.0 chassis, that lowest point is the bottom edge of the gusset where the chassis sweeps up towards the rear spring hangers.
You can see that point in this photo.
I haven't measured off the spring hangers because they are pretty much within the diameter of the tyre - it's pretty hard to get hung up on them in a "belly out" situation.
In any case maloo, what we're all running isn't really that relevant to you. You need to know what works on the terrain you are driving, not on the terrain we are driving.
From one area in Victoria to another my setup is either too long and low or just right. How that's relevant to NSW - I'm not sure.
Post Posted: Mon Jan 09, 2012 1:31 am
Mine will be <21" belly. 96' wb
Post Posted: Mon Jan 09, 2012 1:42 am
33's, 98"wb, 14-16" belly depending on coilover setup.
Users browsing this forum: No registered users and 1017 guests
