It is currently Sun Nov 08, 2026 10:20 pm
Post Posted: Fri Feb 03, 2012 6:11 pm
hey guys my sierra is having some issues with the steering it feels jumpy like i can turn fine and then it will go very hard in certain spots turning both directions.
Post Posted: Fri Feb 03, 2012 7:02 pm
take off the steering damper and see how it feels.... also take the plastic screw out of the top of the steering box and fill it with diff oil or bearing grease (i did 50/50 in mine).
Post Posted: Fri Feb 03, 2012 8:07 pm
I will try taking it off tommrow and if still no change i will fill it and see how it goes
Post Posted: Fri Feb 03, 2012 8:10 pm
Let us know hey! :D
Post Posted: Fri Feb 03, 2012 8:46 pm
try the uni in the steering shaft they seize up
Post Posted: Sat Feb 04, 2012 6:25 am
Last time i had trouble with steering it was a snapped cv, there would probably be the most minor of minor chances that this is you case though. food for thought
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Sat Feb 04, 2012 6:52 am
Which is why it is vitally important to remove the broken CV as soon as you break it. They can and do lock up the steering, even when the hubs are unlocked.
Stewy91 - I think it's likely to be the uni at the firewall end of the steering shaft that's seized. Try dousing it in CRC/WD-40/the penetrating spray lube of your choice, and see if it improves, even just a little bit. If it does, then you know what you need to replace.
Vehicle: 91 WT 1.6EFI
Post Posted: Sat Feb 04, 2012 10:27 am
x2 for the steering uni. that's what if felt like when mine seized
Post Posted: Fri Feb 17, 2012 11:44 am
any update on this? Mine is doing the same thing, took off dampner and no difference. Cheers.
Post Posted: Fri Feb 17, 2012 8:11 pm
yea mate was the uni gave it a bit of degrese and it freed up
Post Posted: Sat Feb 18, 2012 8:57 am
It's likely to only last a little while before it gets tight again. As you have a WT sierra, it has a replaceable uni on the firewall end of the shaft. It's time to get hold of one of them.
PS 1.0litres don't have a replaceable uni - it's welded to the shaft.
Post Posted: Sat Feb 18, 2012 9:13 am
yea its okay its getting power steering soon so ill replace the uni then
Vehicle: 1995 Vitara, SWB
Post Posted: Mon Feb 20, 2012 7:01 pm
I have a similar problem with a 96 SWB Vitara.
From my checking, there are obviously differences between these vehicles steering set ups. I can't locate a uni joint as stated for the sierra.
Where should I start looking for the problem, and what are some possible solutions.
Kev.
Post Posted: Mon Feb 20, 2012 7:38 pm
There are two unis on a vitara. Depending on year one is removable, one isn't.
Theres a few variations.
They aren't easy to spot - they have rubber boots over them.
Post Posted: Mon Feb 20, 2012 7:44 pm
Serious question Steve....will it fit a coily ?
I would like to piss off my steering shaft as I think I am up to uni number 3 in 18months. What other options are available or a better option?
Post Posted: Mon Feb 20, 2012 8:09 pm
Have you bought oem uni for it?
I have noticed some of the aftermarkt stuff is rubbish.
Post Posted: Mon Feb 20, 2012 8:25 pm
No :cry:
Post Posted: Mon Feb 20, 2012 8:26 pm
What's killing them?
Post Posted: Mon Feb 20, 2012 8:40 pm
NFI 8O The angle from the fire wall to the box is ok, but the uni seems to be at a bit of a weird angle, kind of just answered my own question didn't I :roll:
Post Posted: Tue Feb 21, 2012 8:06 am
I got a price a while back of $125 for a genuine replacement uni.....
I found some decent second hand one's for $10 so I bought 2! I'm still on the first one
 Profile WWW ICQ YIM
Users browsing this forum: No registered users and 115 guests
