It is currently Fri Oct 30, 2026 12:28 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2
Vehicle: 94 suzuki stockman
Post Posted: Wed Apr 18, 2012 10:22 am
alien wrote:
i think the issue is that to fit a 5sp box you gotta make some adaptions to the shafts etc. Prolly not really worth it unless you change to a bigger engine.
Im not sure but Ive heard that you can machine the inside of the rear housing of the G/box to fit the 5th gear
Vehicle: Yellow Ute
Post Posted: Wed Apr 18, 2012 10:36 am
Just wear ear muffs and up it.
Post Posted: Wed Apr 18, 2012 10:59 am
From what I've read, the gear set from a 1.3l gearbox will drop into a maruti gearbox.
Not only does it give you a 20% higher top gear (0.8:1 vs 1:1) but you also get a lower first (3.652:1 vs 3.136) so it's win-win really. :)
I don't think a 1l would like pulling that 5th though.
Benchai (I think) did it and made a thread on it but I can't find it!
Post Posted: Wed Apr 18, 2012 11:04 am
HighwayStar?
Lil Foot!
Post Posted: Wed Apr 18, 2012 11:12 am
JrZook wrote:
HighwayStar?
Yeah, his thread was for LJs though, (said thread is here viewtopic.php?f=17&t=12322&hilit=auto )different kettle of fish if you wana keep the linkage shifter. :)
Someone did one a few months ago with a type 3 1l (same process as a Maruti) and I'm pretty sure it was Benchai but I can't find anything. :?
Post Posted: Wed Apr 18, 2012 11:16 am
I actually thought the late model marutis already had 5 speeds ???
Post Posted: Wed Apr 18, 2012 11:32 am
It has....... 4 forward and one reverse. I dont know how many times I went to chuck it from 4th to reverse :oops:
Post Posted: Wed Apr 18, 2012 11:43 am
I always find myself going for that imaginary 5th gear in my 1l. :lol:
Vehicle: Yellow Ute
Post Posted: Wed Apr 18, 2012 11:51 am
I think this is the thread sideways is talking about http://www.auszookers.com/forum/viewtopic.php?f=5&t=28694&hilit=4sp+to+5sp
Post Posted: Wed Apr 18, 2012 12:29 pm
God that ute is clean! Once the speed issue is sorted it'll be a nice score
Post Posted: Wed Apr 18, 2012 12:39 pm
From what I can see there is no evidence that anyone exited the passenger side of the vehicle there is no scuff marks or paint wear on the inner sill, bottom of the door etc, Trust me I will sort the speed out however I don't want to butcher the under the bonnet appearance yet as it very tidy
Post Posted: Wed Apr 18, 2012 12:53 pm
Nice Pic of the engine bay
Post Posted: Wed Apr 18, 2012 1:25 pm
Out of interest I wonder if the air filter has been replace in all those years? Could be a rats nest or something in there haha.
Post Posted: Wed Apr 18, 2012 1:30 pm
if it's only ever putted around a vineyard, it's probably gummed up the exhaust or the secondaries are stuck... as mentioned above it could be a number of things, start with the basics like checking if it's getting full throttle.
Post Posted: Wed Apr 18, 2012 1:37 pm
Well I was told the vehicle was serviced every mth regardless of the k's ...thats 300 odd k's a mth however it was on a vineyard property so it would have been stop start ... I will check the air-cleaner though... was disappointed that there were no Reds under the seats
Post Posted: Wed Apr 18, 2012 1:47 pm
I had no machining to do to drop the gears from a 5sp into the type 3 4sp case. I've heard it said though that it needs to be done, so whether the Maruti 4sp is different to the type 3 I'm not sure. Mine has no problems whatsoever cruising in 5th from as little as 60kph.
I had a problem I couldn't resolve for some time where mine would just die at 4000rpm, then pick up when I took my foot off the gas. Could repeat it reliably all day and it turned out to be a mud wasp nest in the intake hose the body side of the airbox. It had sat stuck to the side for quite a while, then finally fell off suddenly and caused this inexplicable problem.
www.bulldogtrimming.com
Post Posted: Wed Apr 18, 2012 1:50 pm
It must have sat for some time cause before we started the trip there were no holes in the exhaust it was tarnished anodised and very clean... when we arrived the secondary muffler had blown out in several places and all the pipe work was full of holes... the only thing left intact is the catalytic converter ... only wish it had of fallen off ...spose there may be a restriction in it. Has anyone had better performance by use headers and a larger exhaust? Because before I go anywhere I'LL need to do something about it.
Post Posted: Wed Apr 18, 2012 2:07 pm
Well at least you can hear yourself sing even if other can't :D
Post Posted: Wed Apr 18, 2012 2:34 pm
Very nice pickup
If you ever decide to sell it let me know :) hahaha
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Wed Apr 18, 2012 2:36 pm
That's a neat little truck mate, how did you go trying the suggestions so far any luck?
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Wed Apr 18, 2012 6:00 pm
"That's a neat little truck mate, how did you go trying the suggestions so far any luck?"
I haven't had time to do anything yet ...guess Id better get to it and ...actually I have remove the seats and carpet if that's what ya call it. I purchased a PVC molded vinyl floor cover/mat with water proof underlay. hate vacuuming
Post Posted: Wed Apr 18, 2012 7:12 pm
Your tyres look to be over sized. That would make it quite sluggish, and also put your speedo out, meaning you are actually going faster than 80 kph.
Here is my 95 when it was stock. Possibly cleaner than yours? :P You can see a noticable difference in the profile of your tyres to mine.
Post Posted: Wed Apr 18, 2012 7:55 pm
JrZook wrote:
alien wrote:
As a point of curiosity, put it in neutral and revs the balls off it... you can actually hear redline, the engine note changes considerably once you get there - sounds more like a chainsaw =)
Best tech ever!..............
Italian tune-up =P
Post Posted: Wed Apr 18, 2012 9:34 pm
Try a tune up, new fuel filter, new air filter, spark plugs, distributor cap, rotor button, also ensure you are getting full throttle at the carbie, also they have a little mesh filter inside the carbie where fuel line goes in, check timing and ensure distributor is advancing properly when revving.
Post Posted: Mon Apr 28, 2014 8:50 pm
Post Posted: Mon Apr 28, 2014 9:25 pm
I have owned 5 w/t marutis all under 100,000kms and they are gutless as hell.
Extractors, remove the throttle stop under the accelerator, check carb gets full throttle when accel is flat, change air filter, advance timing, 2" exhaust and then after all that effort realise that 30kw of 1ltr grunt just doesnt cut it. Just weld some 1.3 engine mounts in (5 mins) and bolt in the 1.3 ltr and 5spd box all tailshafts ect... fit without mods.
With the maruti gearing top speed will still be quite low and rev heaps but you will have more power and an extra 2500 rpm to play with over the 1ltr which dies at 5500-6000 max
Post Posted: Mon Apr 28, 2014 9:43 pm
This is a project that was suppose to take a few weekends but due to many other projects it got put on the back burner...my hopes are registration in a few weeks then a mild 75mm lift, wheels and extractors...as far as the engine goes I might upgrade it to a M15a after I get the rest of the mods done
Post Posted: Mon Apr 28, 2014 9:54 pm
Upgrading to 245/75/16 tyres and rims sould get you more top speed which you will definately want without sucking massive power the 1ltr gearing handles tyre upgrade better than the 1.3 does.
If going an m series motor you would be silly not to go the m18 for more power same work. Only suzistore has done mseries engine into sierra in perth and its prob gunna push 7-8k if your paying someone to do it.
Vehicle: 92 WT Sierra 1.3
Post Posted: Tue Apr 29, 2014 2:20 am
I've found the terrain you're driving through makes a huge difference and I'm not just talking about hills. Due to the Suzuki's craptacular aerodynamics the smallest amount of wind can knock a lot off your top speed (or so I've found).
Case in point... the trip south of Perth to Bunbury. The newish extension to the Freeway through to where it joins the Old Coast road is relatively flat and has very little in the way of wind breaks (trees and scrub bordering the road) - it's mostly open farmland. On one trip down south this stretch had me screaming the tits off my Zook in 4th just to make 80km/hr. As soon as I hit the Old Coast Road where there's plenty of trees and scrub higher than the car close to the road, it would quite happily do 110km/hr - I've got a 96 WT SWB Sierra with a soft top (which I believe acts as a spiniker during strong winds, I've been known to plan trips around wind speed and direction), 1.3L, 5 speed, extractors, 2" exhaust with a 1 3/4" dumper section at the end and running 215/75/15 tyres (no gearing).
I swear there must also be the slightest rise for the whole length of that boring as batshit road... going south is nearly always a bit of a push for the zook, coming back not as bad... Cross winds bring a rapid tightening of the sphincter but with a strong tailwind I get to feel like a speed demon overtaking all the grey nomad caravans and land barges hauling their sea barges...
If the 600k's were out the Goldfields way, the lack of substantial road-side scrub/trees and the smallest hint of wind might not be helping... Try all the cheaper options the guys here have suggested... Then get the bigger engine...
Post Posted: Tue Apr 29, 2014 2:53 am
Stocky wrote:
we sat behind several road trains for an hr ...because they past us...
Invest in a CB radio and chat to the truckies, I've heard finding one who doesn't mind you tucking into the slipstream can save a bunch of fuel and RPMs...
I always liked the idea of a grappling hook, Mad Max style...
Users browsing this forum: shakes and 217 guests
