It is currently Sat Oct 03, 2026 5:42 am
Post Posted: Thu May 17, 2012 7:43 pm
in desperate need of a new clutch ( as i found out whilst wheelin' )
how much and where ?
diy or get a pro ? or ill pay $$ if someone can help install if i buy the kit :D
Vehicle: Coil Sierra
Post Posted: Thu May 17, 2012 8:31 pm
get a heavy duty as you will be on the clutch alot if u have
standard gearing. Ebay, repco, burson, exeedy eagle farm.
Big job if you havent done a sierra clutch before. Pita removing
gearbox from underneath. Tight fit.
Post Posted: Thu May 17, 2012 9:11 pm
standard gearing.
Thats terrible advise!! (IMO :D )
Get a good quality standard clutch ( exedy ) and put the $100 you save towards gearing. HD clutches suck arse in sierras.
Post Posted: Thu May 17, 2012 9:15 pm
Except for mine :thefinger:
Lil Foot!
Post Posted: Thu May 17, 2012 9:17 pm
But with your vehicle being geared properly, why do you need a HD clutch? :x
It won't last longer, it doesn't have any more friction material..... it just costs more and makes the pedal harder.
Post Posted: Thu May 17, 2012 10:14 pm
i shall look for a exedy OEM replacement.. looking at $150-$180 on ebay
how much am i looking at to get a mech to fit it for us ?
Vehicle: 1985 Holden Drover
Post Posted: Thu May 17, 2012 10:22 pm
If the car a daily? If you can afford to keep it off the road for a day or two just give the FSM a good read and give it a go!
1989 WT Sierra.
Post Posted: Thu May 17, 2012 11:13 pm
A clutch on a sierra is mechanics 101. But re-aligning can be a PITA without a tool, and you MUST get your flywheel machined, so organise this with a clutch or brake place BEFORE you pull your car off the road.
Vehicle: Coily.
Post Posted: Fri May 18, 2012 9:01 am
On this subject i'll have to do the clutch on my Coily soon,is it better/easier to take the motor out or drop the gearbox?.Mechanics are talking a grand+ (including cable) so i'll have to do it myself.TIA.
Regards All from far Northern NSW.
Post Posted: Fri May 18, 2012 9:06 am
just drop the gearbox while engine is in the car, only pita is alligning the clutch back up if you havnt got the tool.. yes its easier when the engine is out but takes alot longer to do it this way.
Post Posted: Fri May 18, 2012 9:09 am
Gearbox out.
Rough proceedure.....
Drop oil from gearbox.
Remove jack shaft.
Remove starter motor.
Remove gearbox shifter.
Undo wiring to gearbox switches.
Remove gearbox mount bolts.
Remove bellhousing bolts.
Shift or lever the gearbox backwards until it drops a little as the spigot leaves the clutch.
Rotate box and shift back until you can get the bellhousing to fall below the motor.
Its out.
All up with a spare set of hands you should be able to do a clutch in under 6 hrs.
$1000 is a fucking joke!
EDIT. You may also have to remove the front driveshaft or exhaust.
Post Posted: Fri May 18, 2012 9:33 am
Replace your rear main seal while your at it :wink:
Post Posted: Fri May 18, 2012 9:39 am
why is life so hard :deadhorse: haha
I'll call around.. and ask around with the ole' facebook friends from school that turned mechanics.. and try my luck :D :twisted:
Post Posted: Fri May 18, 2012 8:43 pm
Its not too hard, just remember what fatzook said, if you dont rotate the box it wont come out. Wish i read how to do it before i started mine, removed radiator, engine mounts and moved the motor a few inches forward, then exhaust had to come out.
Post Posted: Fri May 18, 2012 8:44 pm
Thats the long way round!! :lol:
Vehicle: Coily.
Post Posted: Sat May 19, 2012 10:20 am
Thanks for the Info.,i assume you can unbolt flywheel with gearbox out,how critical is the machining bit,everyone says get it done on the Sierra but i have done several clutches over the years,Datsun,Toyota & Holden and never had a problem by just bolting them on to the untouched flywheel.
Post Posted: Sat May 19, 2012 10:30 am
You wont get your warranty on the clutch if you don't.
Post Posted: Sat May 19, 2012 10:40 am
For the $15 it costs to get it done, why wouldn't you?
Not every clutch destroys the flywheel, but they can create hot spots on it ( depending on the clutch used, drivers use of the clutch etc ), and this WILL effect how the new one works.
Its the same principle as brake disks. They can chatter and pulse if the rotors aren't machined at pad change.
Its just good practice.
Post Posted: Sat May 19, 2012 3:38 pm
BINGO!! :D
Users browsing this forum: No registered users and 209 guests
