It is currently Wed Jun 24, 2026 7:04 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Vehicle: Suzuki Jimny 2010
Post Posted: Sun May 20, 2012 6:00 pm
So I snapped the mount that holds the tie rod to the diff/axle housing today... Can I weld that back on with normal mig wire?
Post Posted: Sun May 20, 2012 6:03 pm
you mean panard rod? tie rod goes to knuckle to knuckle i think
Post Posted: Sun May 20, 2012 6:09 pm
Yes. Ad as per zooky08 it's probably your panhard mount.
Add some gussets so it doesn't happen again.
Post Posted: Sun May 20, 2012 6:11 pm
Yeah knuckle to knuckle to attach t to the sway bar? Am I talking bout the right bit?
Post Posted: Sun May 20, 2012 6:13 pm
We can play the name game for hours or you could post a pic of the offending part and dissmiss the guesswork.
Post Posted: Sun May 20, 2012 6:16 pm
tie rod goes from one knuckle to the other kbuckle behind the diff under the diff center on a jimny, your talking about that rod.
if so, it doesnt connect to the sway bar at all. if your talking about the mount were the rod goes from the chassis down to the diff housing thats the panhard rod, ifs its the mount on the knuckle then that is cast iron im pretty sure and no normal mig wire wont work. like jas said pic would be good
Post Posted: Sun May 20, 2012 6:52 pm
Can't get a pic uploaded at the moment but I'll try in a bit... Cheers guys
Post Posted: Sun May 20, 2012 7:20 pm
Post Posted: Sun May 20, 2012 7:31 pm
Post Posted: Sun May 20, 2012 7:35 pm
not the best pics but the best i can get... looks to be an cast alloy???
Post Posted: Sun May 20, 2012 7:37 pm
Thats a swaybar mount and swaybar.
Its happened to someone else on here before.
Make a new one, make them both stronger on the diff side
Get a new swaybar. That is mangled to hell. what were you doing??
The swaybar is springsteel.
The mount will be mild
Good to see those middle links held up, im using them on mine :lol:
Post Posted: Sun May 20, 2012 7:39 pm
So if i was to make some new ones out of mild steel, i could then weld them in the place of the old ones onto the diff housing?
It's got me beat why they make so many parts that need to be strong out of cast alloy???
Post Posted: Sun May 20, 2012 7:42 pm
What?? Who said it was cast alloy??
Post Posted: Sun May 20, 2012 7:46 pm
I was wheeling out at Killingworth... Still don't know what I hit to break it to be honest... It was a pretty mild day lol.... but... apart from doing that,
My rim had a heap of mud stuck on the inside and got a nasty wobble up at around 60km/h, so I put the spare on till I got home... however 1500m from home I got a major wobble and then all of a sudden the wheel came off and shot down the road, and narrowly missed going through a front window of a house, and ended up stopping after hitting the rear wheel of the triton parked in the driveway (luckily it was there... he normally has a smick 351 Ford GT parked there :S ). So after putting the spare on and started heading home again... My gf spilt iced coffee in the car too :D
Most awesome day of wheeling EVER!!!! NOT!!!
Vehicle: 2003 Jimny Auto
Same happened to my jimny...
It is the best accidental mod i've ever done. You can improve your performance now by remounting the sway bar carefully under your workbench. Sit it on the cement, leaning against the wall so it can't fall down when you are tinkering.
Now go for a drive and enjoy your newfound offroad ability.
And I dont think it's cast alloy...
Post Posted: Sun May 20, 2012 7:48 pm
HOLY CRAP that never happened to me.... i meant the broken swaybar mount
Post Posted: Sun May 20, 2012 7:49 pm
lol yeah I was thinking of leaving it out, but the other half drives it too so I'm a little worried about her hitting roundabouts too hard lol... It just looks to be a cast alloy??? I'll hit it with a grinder tomoz and see what happens... Alloy shouldnt spark should it?
Post Posted: Sun May 20, 2012 7:50 pm
WOW! , Your lucky it wasnt worse!!
The only things cast alloy in a jim will be engine+bits, gbox, transfer.
But yeah, steel/mild steel will spark straight away..
Post Posted: Sun May 20, 2012 7:54 pm
Yeah I don't get how I lost all 5 wheel studs... I made sure I tightened them all by stepping on the tire lever and everything... Just not my day apparently! Just super glad no one got hurt!
Post Posted: Sun May 20, 2012 7:56 pm
My transfer mount is cast alloy?? Snapped it like a twig at the beach lol
I'll try it in the morning... Many beers to be had atm :)
Post Posted: Sun May 20, 2012 7:57 pm
is there any leagalities to leaving the sway bar out? I'd imagine there'd have to be???
Post Posted: Sun May 20, 2012 7:59 pm
Oh yeah jims transfer mounts are too.
Yes definatly. If you have a crash with no swaybar, insurance companies won't like it.
Post Posted: Sun May 20, 2012 8:06 pm
yeah thought as much lol
I'm picking up the new 30x9.5 KM2's tomoz, Josh is comin over Tuesday to gimme a hand to chop the gaurds... Transfer gears are on the way... Need all this sorted before July cause I'm going to do Fraser and Moreton Island :(
Post Posted: Sun May 20, 2012 8:09 pm
Armsup
He will be able to give you advise :D
That amazing sweetheart is marvelous :mrgreen:
Post Posted: Sun May 20, 2012 8:19 pm
Armsup
I've been seeing some concerning posts from you two lately lol... Getting a little worried!!!
Might try and weld the old mount back together for now if I can... Another job for Josh lol
Post Posted: Sun May 20, 2012 8:34 pm
Not good practice, could do more damage than good.
Post Posted: Sun May 20, 2012 8:37 pm
Yeah I know that... Didn't jump up and down on it, just put the pressure on it my rooted shoulder couldn't lol
Post Posted: Sun May 20, 2012 10:34 pm
And CVs.
I can weld It on if you need a hand.
Post Posted: Mon May 21, 2012 8:50 am
This comment comes up so often and I usually just laugh and say nothing, however I don't know you and have not read your posts before so for what it is worth here is my 2 cents worth:
Why worry about the legalities of running a sway bar or the poor handing for your girlfriend without a sway bar when you going to make the car illegal by choping guards and running big tyres. The reason those big tyres are illegal on your car is because engineers who know what they are on about say that they will adversly affect the safe handing of your car and make your car more dangerous at speed on the road due to the added unsprung weight and extra stresses they will put on your mechanical components.
Seriously DOT and cops are going to pull you over for tyres and chopped guards long before they will notice you have no sway bar fitted, if you crash they may not even notice the missing sway bar unless your crash warrants a mechanical inspection (which most crashes dont) but they will notice that you have bigger tyres.
So I guess what I am trying to say is if you are concerned about insurance and legalities stay within the confines of the law with everything on the vehicle. If you want the benifits of no sway bar in the bush but still want the benifits of sway bar on the road maybe you should ty to source a sway bar quick release kit for your car.
(By the way, personally I think the tyres you are getting and the size you have chosen are not too big, if I had a Jimny that would probably be the size I would try to run as well, they are a good choice)
Post Posted: Mon May 21, 2012 1:16 pm
And CVs.
:lol:
xx
bye
Users browsing this forum: fordem, Google [Bot] and 127 guests
