It is currently Tue Sep 29, 2026 11:48 pm
Post Posted: Wed May 23, 2012 4:28 pm
Hey, so I am doing another G16B conversion in a zook that currently has a GTI engine..
Just double checking to see if the starter motor, flywheel and clutch of a GTI is the same as what you would get off a Stock Sierra 1.3L engine? Because the blocks are the same or really similar as the Sierra box and engine mounts bolt straigh up right?
Just preparing myself to see wether I will need to sourse a Sierra Starter motor, flywheel etc for when I swap those bits onto the G16B.
Thanks guys,
PS, Looking for a good running G16B too..
PM if you have one please
Post Posted: Wed May 23, 2012 9:16 pm
Flywheel and clutch are same.
1.3 starter will need grinding down on the block side.
Check the damaged vehicles auctions for 2000+ Baleno's.
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Wed May 23, 2012 9:37 pm
98+ baleno's should be all coil pack. tho i've seen 97's with coil packs where the dizzy usualy is instead of sitting on top.
We are amphibious
Post Posted: Wed May 23, 2012 9:49 pm
Nah I meant there's thousands of them. :roll:
:rofl: Kidding...
Ok so maybe 97 onwards.
Post Posted: Thu May 24, 2012 8:48 am
Sweet as then, I got told the gti fly wheel is lighter then the 1.3 zook flywheel?
Vehicle: SJ51T
Post Posted: Thu May 24, 2012 9:12 am
Apparently they are but i didnt notice any real difference when i swapped mine over. The main difference between my sierra and GTI one was that my GTI flywheel was flat and the sierra one wasnt.
Post Posted: Fri May 25, 2012 12:29 pm
You can't interchange the fly wheels
You have a sierra flywheel in there
Vehicle: LJ50 , LJ80Q-II
Post Posted: Fri May 25, 2012 1:29 pm
A Mk1 gti flywheel can be used . they are thinner and lighter than the 13a ones.
most people use The 13a flywheel for a little more low down tourqe.
Users browsing this forum: Google [Bot] and 152 guests
