It is currently Sat Sep 26, 2026 9:51 pm
Post Posted: Sun May 27, 2012 1:57 pm
Hey guys when I was 4x4ing my Suzuki Jimny 2001 model I tired to change into 4x4 drive and all the light does is flash and my 4x4 doesn't Engagge?
Post Posted: Sun May 27, 2012 1:58 pm
Could be a vaccum solinoid problem?
Post Posted: Sun May 27, 2012 1:59 pm
Like bluesuzy said, or vacuum hubs aint working
Also check if your lines Havnt come off
Post Posted: Sun May 27, 2012 4:11 pm
mine flashes now I have manual hubs, any one know how to stop it flashing?
Post Posted: Sun May 27, 2012 4:13 pm
Yep pull hard lines off diff and block rubber tubes
Vehicle: 1999 Jimny
Post Posted: Sun May 27, 2012 7:50 pm
So this would be the same for a GV??????????
Post Posted: Mon May 28, 2012 1:18 am
Nope - the GV doesn't have a vacuum operated front free wheel system - which of the GVs do you have?
First generation GVs (98~05) use a positive pressure (vacuum is negative or the absence of pressure) free wheel system, a flashing light is usually caused by an air leak in the system, second generation GVs (06~) have an electrically shifted transfer case (if fitted with the four mode 4WD) and a flashing light indicates the actuator(s) and the switch are not in sync (or at least the controller thinks they are not), it can be caused by broken wires and defective switches..
Post Posted: Mon May 28, 2012 9:10 am
I took the lines off just back from the diff, where the solid vac lines goto a t-piece to each hub. cut the tip off some golf tees, shoved em in as far as i could with a screwdriver, and reconnected em. that way you only have to block 2 lines, not 4
MY BUILD THREAD HERE!!!!!
Vehicle: 02 GV
Post Posted: Mon May 28, 2012 9:23 am
mine did this, 4x4 worked still but I found a tutorial on how to fix, can't remember where, it may have been on here, mine had a rusty valve in the pump, everytime the pump cycled the light would flash. now that I cleaned the rusty valve it holds pressure and doesn't cycle.
very easy job to do.
Vehicle: 1999 Jimny
Post Posted: Mon May 28, 2012 3:39 pm
2000 model GV, flashes all the time & it's a piss off.
Post Posted: Mon May 28, 2012 5:47 pm
Its going in and out of 4 wheel. This is what you call part time 4WD :rofl:
Post Posted: Tue May 29, 2012 5:05 am
Rapid flash - 1 sec on/1 sec off type thing - or occasional wink out - 30 sec on/1 sec off ?
Either way you probably have an air leak, the light winks out every time the pump turns on, so the more frequent the flash, the bigger the leak is.
Look behind the front bumper and find the pump - disconnect the output hose (the one that leads back along the frame rail to the crossmember) and plug the outlet, and observe the light, if it stays on your leak is downstream from where you plugged it, work your way back through the hoses to the diff connector - if you don't find a leaky hose, the actuator in the diff may have failed..
If it continues to flash with the pump outlet plugged, the problem will be in the pump itself - it may or may not be repairable - there is a pictorial teardown in the good tech section, if you want to have a go at fixing it.
Vehicle: 1999 Jimny
Post Posted: Tue May 29, 2012 5:25 am
Thanks champ, that'll be part of this weekends fun!!
Users browsing this forum: Google [Bot] and 112 guests
